Photo of timed up dizzy needed please
Old Jul 11, 2010 | 02:59 PM
Sonic Boom's Avatar
Sonic Boom
Default Photo of timed up dizzy needed please
Can anyone set cylinder 1 to TDC and then take the dizzy and rotor arm off then take a photo of how their phase sensor is timed up please.
Cheers Rich
Old Jul 11, 2010 | 04:39 PM
I might have a drawing of the tis disc if you want ?, all lined up but dead easy to do, mark on dizzy body top(scribed line) should fall in centre imaginary line of the dizzy arm pointer.
Old Jul 11, 2010 | 05:29 PM
AndyPen's Avatar
AndyPen
As tab says - but sometimes the dissy twists if you have removed it so you have take account of this by twisting it before popping it back in - easy enough.
Old Jul 12, 2010 | 01:34 PM
Sonic Boom's Avatar
Sonic Boom
Does it matter where the dizzy actually is?
ie; the outside of the dizzy where the plug is
Or as long as the centre line of the rotor arms lines up with the scribed line it's ok?
Cheers Rich
Old Jul 12, 2010 | 03:41 PM
AndyPen's Avatar
AndyPen
It can be a bit tight on the leads if it twists around too much - not much space down there.
Old Jul 12, 2010 | 04:10 PM
Sonic Boom's Avatar
Sonic Boom
Ye but does it matter timing wise?
Old Jul 12, 2010 | 05:22 PM
Doesn't matter where the dizzy body is in relation to the engine so long as the end result is obtained, ie if it's easier say to rotate 1/4 turn that's ok and will cause no issues so long as the rotor arm/phase signal is in line with the body, just take out turb slightly as said take account of how much it turns as it goes back in then get it where you want it to end.
Old Jul 12, 2010 | 05:32 PM
Sonic Boom's Avatar
Sonic Boom
Ok cool it's definatley timed up properly then, gotta be something else wrong.
Cheers Rich
Old Jul 12, 2010 | 06:17 PM
AndyPen's Avatar
AndyPen
Cheers Rich
Didn't realize you had a problem mate? Is it dead then... fuel or spark issue? Crank sensor is often the culprit you see.
Old Jul 12, 2010 | 09:28 PM
COLEYST200's Avatar
COLEYST200
when i came over RICH i set it up as it should be set and it didnt wot on the dizzy or the cam so the problem on your car is mot there you need a second loom to try on your car . Did you ring the number i sent you . all so RYAN ran me yesterday to have a second chat about it and said he was going to ring you today about it . Did he ring you
Old Jul 12, 2010 | 11:21 PM
Sonic Boom's Avatar
Sonic Boom
Ye spoke to Ryan he's going to have the loom back to check it over.
Rich
Old Jul 12, 2010 | 11:26 PM
COLEYST200's Avatar
COLEYST200
let my no wot he finds mate
JoeyBoyden
Jan 4, 2024 02:36 PM
yawiejon
15
Aug 9, 2015 06:36 PM
bassboy
Aug 8, 2015 10:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
