boost level
Old Jun 30, 2010 | 10:08 PM
smartrs's Avatar
smartrs
Default boost level
whats the best level to set my boost at ? ive just fitted another turbo its a t34 .63 and i had to adjust the actuator rod to fit and i just wondered what my boost level shoud be set at ?
t34 .63 greens and 500 style cooler the engine has recently been rebuilt ,
just wondered what boost is best ?
Old Jun 30, 2010 | 10:15 PM
Danny @ Enhanced Performance's Avatar
On greens you can have a big boost spike of around 28 psi but holding around 22 psi
You will have to have it set up properly for that though..
What chip you running???
cheers danny
Old Jun 30, 2010 | 10:23 PM
smartrs's Avatar
smartrs
it was in the car think its pts for greens 3 bar and T34 . i'm thinking of changing chip and injectors soon but just want to know where to have it until then which wont be long if i get my way
Old Jun 30, 2010 | 10:28 PM
If your not 100% just run about 1.5 bar(21psi)if its all running spot on untill you get some new siemens and a live map..
cheers danny
Old Jun 30, 2010 | 10:31 PM
Staffi's Avatar
Staffi
Greens are pretty much flat out at around 340 -350 or so anyway, infact i've seen them running 90% duty just @ 310bhp @ 22psi....
As Danny says, just be CAREFUL until you've had it setup properly
Old Jun 30, 2010 | 10:34 PM
Yes your right in reality greens will only give a genuine 350 hp max and thats if your lucky!!
cheers danny
Old Jun 30, 2010 | 10:36 PM
smartrs's Avatar
smartrs
i am happy with it all i have been offered some greys and chip from a mate which i may go with until i feel the real urge for live mapping and siemens
Old Jun 30, 2010 | 10:38 PM
smartrs's Avatar
smartrs
the car will be off to my local tuner for setting up to be safe just not live mapping as yet .
Old Jun 30, 2010 | 10:40 PM
smartrs's Avatar
smartrs
so were agreed 1.5 bar to be safe on greens and get a set up at least
Old Jun 30, 2010 | 10:45 PM
Staffi's Avatar
Staffi
Yep, 1.5 bar will be fine, just get that fuelling etc checked.........
I take it your pump has/is re-wired yes??
Old Jun 30, 2010 | 10:54 PM
smartrs's Avatar
smartrs
yes it has
Old Jun 30, 2010 | 11:02 PM
Ginge !'s Avatar
Ginge !
just finding my feet
wack it up to 50psi,,,, have fun for 20 mins then rebuild so it can actually handle that pmsl
Old Jun 30, 2010 | 11:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Regardless of the info on here at the moment, my advice is to call the chip calibrator and see what its mapped for as you say you "think" its for a T34. If it is in fact a T3 and you have fitted a .63 T34 you can say goodbye to your engine at 22psi and high revs.
Old Jun 30, 2010 | 11:10 PM
smartrs's Avatar
smartrs
ok lets try it on yours first mines just on a fresh rebuid and i got other bits like making the rest of the car shine and fix the body work niggles
Old Jun 30, 2010 | 11:13 PM
smartrs's Avatar
smartrs
ill go with stus advice
thanks stu
Old Jun 30, 2010 | 11:33 PM
Ginge !'s Avatar
Ginge !
stu PTS are no longer trading which could also cause a issue,,,, id recomend a drive up to stus for a new chip as he TOTALLY changed my old saph and it drove like a dream after,,, and mine was the same spec apart from a pair of BD10s
Old Jun 30, 2010 | 11:42 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
PTS only copied chips they never mapped anything
Old Jun 30, 2010 | 11:44 PM
Ginge !'s Avatar
Ginge !
i know that,,,, but how do you know who they copied,,, thats gonna be harder to ask a company that is no longer trading that stole maps of others and sold them on as there own,,,,,,, or did they just copy yours pmsl
Old Jun 30, 2010 | 11:54 PM
smartrs's Avatar
smartrs
basicly my chip is not worth a monkeys toss lol so right new chip required more money just wish i knew which direction i was going in lol so i dont buy another chip then change spec then need anoter chip later on
Old Jun 30, 2010 | 11:56 PM
Ginge !'s Avatar
Ginge !
get the fueling checked with the chip you have,,,, that will give the guy whos setting it up a idea,,,,,, then plan from there
Old Jun 30, 2010 | 11:57 PM
Turbosystems
Super Moderator
siemens 55lbs and a live map is the way to go
Turbosystems
Super Moderator
greens are only any good on a t3 yb
Old Jun 30, 2010 | 11:59 PM
Ginge !'s Avatar
Ginge !
spoken like a true salesman,,,,, but he IS right tbh should be a MIN spec for all cossies T34, 55lb, 500 cooler dialed in cams and just have fun
fucking wish subaru tuning was as easy !!!! fucking poxy shed of mine !
Old Jul 1, 2010 | 12:02 AM
smartrs's Avatar
smartrs
whats a rough price on that ? ball park ? and what power would that give ?
i will check the chip tomorrow to see whos it is and double check , will i need any other info off the chip if its not pts chip and there is some one to contact ?
Old Jul 1, 2010 | 12:09 AM
Turbosystems
Super Moderator
4x4 cooler is fine
Old Jul 1, 2010 | 12:13 AM
smartrs's Avatar
smartrs
mine has a 500 cooler std cams as i was stuped and did not have cut out machined into te pistone when the car was re-built
Old Jul 1, 2010 | 12:17 AM
Turbosystems
Super Moderator
it will wok fine on standard cams change the injectors get it live mapped and set up
if you are flush stick an ahmed bayjoo inlet cam in there like steve 4i has just had
Old Jul 1, 2010 | 12:19 AM
whats a rough price on that?
Price for just the ECU chips:
Price / info on drive in drive out conversion:
Parts alone can be found here:
Old Jul 1, 2010 | 12:33 AM
smartrs's Avatar
smartrs
scary i nearly hit the paypal button , what would be the advantage over the live map rarther than buy the off the shelf items ? all the checks that will be done or is there other differances ?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
