cosworth car horns
Old Jun 30, 2010 | 10:02 PM
smartrs's Avatar
smartrs
Default cosworth car horns
did cosworth offer air horns as a optional extra as my saffy has them fitted ? there proper ford ones they have te ford badge stamped on the air pump . mine are disconected as i really dont like the sound . but only one of my normal horns works and that sounds a little camp too .
where can you get replacement ford electronic horns or is it just a case of buying aftermarket jobbys ?
Old Jun 30, 2010 | 10:07 PM
R4N SS's Avatar
R4N SS
they had two horns fitted to them
Old Jun 30, 2010 | 10:15 PM
smartrs's Avatar
smartrs
air horns ? not electronic but air horns mine has 2 eletronic horns as well as these air horns
Old Jun 30, 2010 | 10:44 PM
smartrs's Avatar
smartrs
any one else got the air horns ?
Old Jun 30, 2010 | 11:08 PM
ProjectBobcat's Avatar
ProjectBobcat
they are listed in the accessory brochures i have from the 80's for any model, assume the cossie was the same
Old Jun 30, 2010 | 11:16 PM
smartrs's Avatar
smartrs
they are very neaty installed but so 1980's lol guess just any decent set of aftermarket horns will do
Old Jul 1, 2010 | 04:24 AM
just go to a local motor factors and buy a horn. Ive just put 1 on my cossie the other week. Mine only had the one connection on which is the live feed wire. The horn i fitted had to connections on. I just made a bit of wire up and used this to earth the horn out on the bracket.
Old Jul 1, 2010 | 08:14 AM
Iain Mac's Avatar
Iain Mac
I've got a box of used Ford electric horns in my shed, all from Mk1 XR4i or Mk2 XR4x4 - they look the same.
They have two different tones though, so you will want the deeper one if yours is a bit "camp" - from memory, I think they have a code moulded on the side that would positively identify which one of yours is working.
Don't know what they cost to post but I'll box one and send it for £8.
Old Jul 1, 2010 | 09:05 AM
mulla's Avatar
mulla
funny you should say that i was under my cossy yesterday and found a set 2 also normal horns thought it was going to play the dukes of hazard lol.
Old Jul 1, 2010 | 09:15 AM
smartrs's Avatar
smartrs
up in the left hand wing ? are youre wired up the air horns ?
Old Jul 1, 2010 | 09:29 AM
mulla's Avatar
mulla
yeah thats were they are havent tryed them but had a quick look at the wireing
Old Jul 1, 2010 | 09:31 AM
RS LOZWORTH's Avatar
RS LOZWORTH
slightly off topic... but how easy are the horns to change because the ones on my escort sound like someone drowning!!!! need abit of loudness! can you just change them with new ones or do i need wiring etc??
Old Jul 1, 2010 | 09:36 AM
smartrs's Avatar
smartrs
if there the same as the saph ones there s one wire to the horn which is the live and the negitive is through the chassis if you get aftermarket ones that the negitive is another termanal on the horn just un a wire from this to a ring connector to the horn mounting bolt
Old Jul 1, 2010 | 09:40 AM
RS LOZWORTH
nice one, i will give it a go! thanks
Old Jul 1, 2010 | 05:23 PM
I fitted a NAUTILUS air horn each side, these are a compact air horn with two short trumpets on each horn, 135db, seriously loud, so I went overboard as usuall, I would be plenty loud enough on it's own.
Just ordered a OOOGAAAAHH horn from the bay for the cossie as well, as my bubble gum pink caliper paint!!
Old Jul 1, 2010 | 05:51 PM
RichieST's Avatar
RichieST
http://www.hornblasters.com/video.php
Get one of these bad boys
Old Jul 1, 2010 | 06:18 PM
St3V3_C's Avatar
St3V3_C
Proper LOL
Old Jul 1, 2010 | 09:24 PM
smartrs's Avatar
smartrs
i'm trying to get away from the air horns else id just wire in the orignal ones that are on the car its just the left hand electronic horn does not work so sound a bit shite with only one tone
Old Jul 1, 2010 | 09:46 PM
cossiegreg1's Avatar
cossiegreg1
my old sapph had ford air horns fitted. i liked them tbh
Old Jul 1, 2010 | 09:56 PM
smartrs's Avatar
smartrs
it may just be the air horns dont sound that good because only one of the electronic horns fire off with it , making it sound like the horn on a clown car HARRR ha
Old Jul 1, 2010 | 10:47 PM
Bungle's Avatar
Bungle
mmm wonder what the air horns sound like im quite keen on them tbh might look out for some ford ones
Old Jul 1, 2010 | 10:58 PM
smartrs's Avatar
smartrs
think the ford ones are no different to the twin air horn you can buy except the ford badge is on them
Old Jul 3, 2010 | 08:36 PM
Bungle's Avatar
Bungle
ahh got some 1970's maserati ones on my escort atm and they sound a bit errrr strange lol
manuel boeckx
13
Oct 3, 2015 02:29 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
