Mk6 rs2000
Got a thick black pipe hanging near radiator not connected and i cant see where its connected to its not wet im bloody puzzled ..Cars not running hot and running well just about to consult haynes manual ..any one got any ideas
no shouldnt be, as long as it is the black tube that goes up to a black box hucked onto side of your manifold.
if it were anything else I guess it wouldnt be runnign as wel as you say it is anyway.
Was not correcting you Kev, as I know you know whats what, and like me you must get sick and tired of correcting everyone!
It was for everyone else's attention.
EGR = exhaust gas recirculation, which I believe is for emissions/enviro reasons and does what it says, re-itroduces exhaust gases back into the inlet system.
APS = air pulse system and is used to bring the CAT up to heat quickly, as they only work once hot enough and again is for emission reasons, and it does this by bleeding fresh air into the exhaust manifold, which allows any un-burnt fuel present to combust and generate more heat in the exhaust and heat the CAT quicker. This usually only runs from a cold start up.
Fordmad!
15
Sep 27, 2015 06:24 PM
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
Vacuman
Sep 22, 2015 12:09 PM
) but then i know the difference lol
