megasquirt msq anyone ???
just wondering if anyone has a base msq for a std set up running std zetec coil pack
i have fully mapped my zetec turbo on my escort about 3 years ago but need a refresher course
so if anyone can help it would be great
my spec is
erst block
frst inlet/flywheel/pick up
frst inlet std injectors
piper 285t cam
stg3 turbo tec turbo
ms1 v3
tommy
my spec is
erst block
piper 285t cam
ms1 v3
tommy
i can send you my rough msq from my ms2 v3.0 extra code 2.1.1 if you like.
you could extract the useble settings if you liked, would need your email address, it's on a 1.8zvh, karlos's is on a cvh 1600 same injectors as me though.
As I replied in your PM's unless your at the very least the same CC and using the same injectors the fuel map is no use, probably wont even start.
The spark map from Sean you could use but pull it all back at least 5deg to be safe and go from there.
thanks for your help
tommy
1.8 esc
11
Jun 22, 2006 12:48 PM
