sierra cos electric windows not working
Old Jun 26, 2010 | 06:30 PM
FiestaZS1700's Avatar
FiestaZS1700
Default sierra cos electric windows not working
hi everyone , my neighbours got a sierra and his electric windows have stopped working all off a suden he said hes had a problem with the fan it keeps kicking in when the cars parked and draining his battery he took it a garage that apparently fixed it but now the windows have stopped working its probably just a coincedence but i was wondering if it could have been something they have done hwile trying to fix the fans also is there a fuse for the electrics windows ? cheers
Old Jun 26, 2010 | 06:49 PM
jon@work's Avatar
jon@work
electric windows fuse = 24
If he's been having issues with the radiator fans, then it's more than likely that the fan fuse area of the fuse box has melted (common problem) and the issue is melted wires in the fuse box touching others where they shouldn't.
Best bet would be to try to investigate the fuse box if a simple window fuse change doesn't sort out the problem.
Old Jun 26, 2010 | 06:51 PM
FiestaZS1700
ok thanks mate ill go and have a look at it now.
Old Jun 26, 2010 | 07:16 PM
FiestaZS1700
yeh it was a blown fuse and looks like the relays gone , thanks for the help mate
Old Jun 27, 2010 | 11:15 AM
Tell your friend to get his fan rewired immediately if still on the original wiring.
pegaz
Aug 12, 2015 07:30 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
