Stage one, saff cos 4x4, Boost?
Jun 20, 2010 | 08:45 PM
What boost will a stage one saff peak at? running approx 270.
Jun 20, 2010 | 08:47 PM
Normally hold about 1 bar dont they, so peak about 17psi?
Jun 20, 2010 | 08:48 PM
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Normally you can squeeze about 16, 17psi out of them for a split second peak but hold around 14.5 (1 bar) on a Stage 1.
Jun 20, 2010 | 08:56 PM
Quote:
Originally Posted by
Lee Reynolds
16psi ish; but assuming you are on yellows, you've got to be careful they arent maxed out
you see some yellow do 300hp and some only do 250hp, so you've got to be careful - fueling check will be good advise if its a new car
Jun 20, 2010 | 09:15 PM
LHD220Turbo
Theyre dark blue mate
I think im underboosting then, not quite hitting a bar BUT i'm unsure if i trust the cheap looking gauge TBH!
Reasonably priced without going ott gauges?
Jun 20, 2010 | 09:23 PM
Lee Reynolds
should be ok then on blues (if my memory serves me correctly!)
persoanlly i'd get it set up by someone who's got the ability to do a fueling check too, it could be loads of reasons why you're not getting full boost. shouldnt cost any more than Ł200 for a set up/check
it could be the actuator needs adjusting for more boost or the actuator could be fooked
Jun 20, 2010 | 10:25 PM
Jun 21, 2010 | 07:16 AM
what colur is the illumination on the gauge?
Jun 21, 2010 | 07:20 AM
This is a pic of it illuminated:
Jun 21, 2010 | 08:17 AM
I bought one of these gauges for my nova
top bit of kit.
Jun 21, 2010 | 09:44 AM
Stu @ M Developments
Cheers stu.
Jun 21, 2010 | 04:06 PM
Nice one ill order one of those off you i think Stu
Cheers lads, i AM gonna get it setup but im also thinking 3 bar, greens and chip while im at it
Jun 21, 2010 | 04:07 PM
im fancying 1 myself lee.
Jun 21, 2010 | 04:09 PM
Ordered, looks nice that for the price, Matt
Jun 21, 2010 | 09:21 PM
Thanks for your business Lee, Im sure you will love it, they are exceptional for the price and perfectly accurate against our test gear.
Jun 21, 2010 | 09:56 PM
No probs Stu! I like the service from your place, always spot on fast delivery! got my sensors from you last week! Still not fitted the phase and crank one yet though! Next job on my list
JK12
33
Apr 26, 2021 12:09 PM
tib2220
Sep 14, 2015 12:33 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
