Best way to remove tar?
Old Jun 17, 2010 | 10:49 AM
Ash170990's Avatar
Ash170990
Focus RS 0268
Default Best way to remove tar?
Gave the Focus a bit of a bufty last night and noticed theres soo much tar around the bottom half of the car, it does come off with a bit of hard scrubbing but im not sure if this is scratching the paint or not, and obviously dont want it too!
Basically i just want to know whats the best way of removing this as i used some turtle wax bug and tar remover stuff last night and that didnt work too well, also had some auto gleam tar remover laying about which also wasnt amazing.
I got rid of most of it last night then quickly went round with claybar and then some meguires wax and i think it looks good (nothing compared to most of them on here but clean compared to what its normally like) but just for future reference.
Old Jun 17, 2010 | 11:53 AM
dakar's Avatar
dakar
Clay bar works well or i use petrol
Old Jun 17, 2010 | 12:01 PM
H7 CYA's Avatar
H7 CYA
Autosmart Tardis is amongst one of the best products out there... Good value too.
http://www.polishedbliss.co.uk/acata...dis-clean.html
Old Jun 17, 2010 | 12:10 PM
Ash170990's Avatar
Ash170990
Focus RS 0268
Yeah, i started off using the claybar, but the tar just seems to smudge all over it and then it was soon unusable after a couple of panels.....
Thanks mate, i will get some ordered and give it a try
Old Jun 17, 2010 | 12:14 PM
JK12's Avatar
JK12
autoglym tar remover - Ł7 halfords - works great on my white ST
Old Jun 17, 2010 | 12:17 PM
H7 CYA's Avatar
H7 CYA
AG's not bad but still takes a lot of scrubbing and some bits are still left behind.
Tardis you just dilute spray on leave for 5-10 minutes and wash off, any stubborn areas might need a bit of a fettle. But is noticeabley better than AG IMO.
Old Jun 17, 2010 | 12:20 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I presume anything that removes tar also removes wax, so the car will need re-treating afterwards?
Old Jun 17, 2010 | 12:25 PM
Brian's Avatar
Brian
I have always used Autoglym Tar Remover
Brian
Old Jun 17, 2010 | 12:35 PM
vroomtshh's Avatar
vroomtshh
Correct.
And tardis is the bomb. Spray on, wipe off, job done
Old Jun 17, 2010 | 12:47 PM
RSLUBBY's Avatar
RSLUBBY
Autoglym tat remover for me and stubburn bits petrol then polish going to try that tardis now as that seems very easy
Old Jun 17, 2010 | 01:07 PM
_SpeedX_'s Avatar
_SpeedX_
tried TFR ??
Old Jun 17, 2010 | 04:31 PM
Rsmat's Avatar
Rsmat
i use petrol on a cloth nd wipe it off...then repolish,wax and seal.
Old Jun 19, 2010 | 05:35 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Dont try and rub it off untill you have treated it with something first,if you have been rubbing the tar with no chemicals you will leave tiny scratches in your clear coat,i see it every week on loads of cars
Tardis is very good but can still take a couple of applications before it safe to wipe the tar off
Old Jun 23, 2010 | 06:23 PM
I could do with some of this for the wifes car.Its always covered in tar.
Old Jun 24, 2010 | 12:06 PM
Mike C's Avatar
Mike C
The Special One
Autosmart Tardis is fantastic, easily the best.
Old Jun 25, 2010 | 07:28 PM
opposite lock's Avatar
opposite lock
yep as above tardis is exellent , use neat and spray on and leave it for 60 seconds then wipe away . Dont use it on fresh paint though !! its solvent based , re apply your lsp afterwards
Old Jun 25, 2010 | 07:45 PM
RUBY123's Avatar
RUBY123
why waste money on these products wd40 job done and you will all ready have it
Old Jun 25, 2010 | 07:48 PM
gouch1's Avatar
gouch1
agree wd40 is good and cheap
all halfords products are overpriced
Old Jun 26, 2010 | 09:12 AM
martysmartie's Avatar
martysmartie
Autoglym intensive tar remover or as said Petrol also works.
Martin
Old Jun 27, 2010 | 10:51 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
I use my teeth.
Old Jun 28, 2010 | 06:02 PM
oggyst's Avatar
oggyst
Wink
Ive always used wd40 & does the job fine
Old Jun 28, 2010 | 06:15 PM
Chris84's Avatar
Chris84
Yea same on my missus silver fiesta all at the bottom looked amess. Wd40 now looks mint again
Old Jul 14, 2010 | 08:52 PM
79Fordboy's Avatar
79Fordboy
I used to use petrol on a rag but find that WD40 does the trick just as well and I don't get high inhaling the fumes!
Old Jul 15, 2010 | 11:31 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
i thought getting high inhaling the fumes took the boredom out of it??
Old Jul 15, 2010 | 09:56 PM
79Fordboy's Avatar
79Fordboy
Old Jul 15, 2010 | 10:56 PM
malescort's Avatar
malescort
Panel wipe cuts through tar spots like butter, just like it removes greasy marks out of your carpet indoors, after transferring grime and crap off the soles of your feet after working on your motor from where it came from in the first place
Old Jul 25, 2010 | 12:43 AM
kidsRS's Avatar
kidsRS
"Ill check the stock"
^^^^ Panel wipe ^^^^^
Old Jul 26, 2010 | 04:56 PM
GrimV8's Avatar
GrimV8
Smokin'
Panel wipe is not good for dogs BTW
Had a rag in my hand after just cleaning a panel, it was almost dry and the dog did the limbo under a MK VII Jag which got grease on her back. One swift wipe and you'd think I'd put acid on her back wasn't right for hours
Great on tar though
Old Jul 27, 2010 | 11:45 PM
RSEDD's Avatar
RSEDD
Ive always used white sprit then just reapplied polish or wax after, always worked for me....
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
