zetec flywheel problem
Old Jun 7, 2010 | 08:41 PM
16vzetec's Avatar
16vzetec
Default zetec flywheel problem
i have a silvertop zetec.
i need some small headed flywheel bolts for my project.
the trouble is i thought i'd buy the small torque headed bolts from the black top zetec but only to find out they are smaller threads so they are no good.
has anyone got any ideas on what bolts i can use so i can have a smaller head or even an allen key type bolt will do.
i cant get a socket over the standard silvertop zetec bolts on my project to tighten them up!
Old Jun 8, 2010 | 09:25 AM
JesseT's Avatar
JesseT
It's usually easier to grind/machine the socket.
Old Jun 8, 2010 | 04:43 PM
As said grind socket or justy take one along to bolt shop and match up with some cap heads.
Old Jun 8, 2010 | 07:27 PM
16vzetec's Avatar
16vzetec
the hole is the same size as the std bolt head so i cant get a socket over it.
i need a different type of head on it.
how do people fit blacktop zetecs into earlier fords? the black top has different size flywheel bolts dont it?!?!?!?!??!
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
