4x4 brake problem
Old Jun 6, 2010 | 07:52 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default 4x4 brake problem
If i sit stationery and press hard on the brake pedal, i get the hand brake light and abs light up for a few seconds, is this a common problem
cheers
Old Jun 6, 2010 | 08:06 PM
jon@work's Avatar
jon@work
check the fluid level
Old Jun 6, 2010 | 08:13 PM
ASHCOSSIE's Avatar
ASHCOSSIE
fluid level is ok, did hear a relay clicking like mad from passanger footwell just before it happened though
Old Jun 6, 2010 | 08:43 PM
jon@work's Avatar
jon@work
If the fluid level is low, the ABS relay turns off, and the handbrake and ABS lights will turn on. Definitely sounds like low fluid level to me.
Old Jun 7, 2010 | 09:59 PM
ASHCOSSIE's Avatar
ASHCOSSIE
fluid is fine have tried disconnecting the plugs on the fluid bottle and the light comes on straight away, unlike my problem where it only comes on when i push the peddle down
Old Jun 8, 2010 | 04:46 PM
Top the level up 1/2" ABOVE top mark.
Old Jun 8, 2010 | 07:49 PM
ASHCOSSIE's Avatar
ASHCOSSIE
just to add as soon as i press the brake peddle the pump kicks in for a couple of second and when it switches off the lights go off
jason_nike
Aug 18, 2019 10:53 AM
c20tbo
Aug 17, 2015 10:19 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
cossie4x4
Aug 14, 2015 06:29 PM
Old ford
Jul 31, 2015 06:50 AM
