mk1 focus RS.. Problems??
Old Jun 4, 2010 | 04:30 PM
pee vee's Avatar
pee vee
Default mk1 focus RS.. Problems??
Hi all,
What are the common problems with them then? Things to look out for?
I hope to be looking at getting one at some point in the next few months...
What am I gettin myself into then??
Thanks!
P
Old Jun 4, 2010 | 09:51 PM
rstdave's Avatar
rstdave
As above lol......we want to know if they're as good or bad to live with as you read about
Old Jun 5, 2010 | 05:18 PM
knighty444's Avatar
knighty444
Originally Posted by pee vee
Hi all,
Thanks!
P
There all good lads.... there gunna hold there money as there a limited run, enthusiasts own them so there pretty much all looked after propperly. The only common problem is usually the chargecooler pump gives up u can tell by lookin into the chargecooler pot wer u top it up n there should b a constant jet of water commin out of a small hole ( sometimes it just blocked and can b cleared by puttin a pin in the whole) if the pumps gone u can get 1 off ebay fo £90 brand new... best car i've owned so far. N with a few mods can easily make 270-300bhp figures... and the std brake n suspension setup is all good too
Look in here all ur answer 2 q's will deffo b answered
http://bbs.rsownersclub.co.uk/forumdisplay.php?f=134
Old Jun 6, 2010 | 09:03 PM
pee vee's Avatar
pee vee
Excellent!
Charge cooler pumps.
leaky sumps?
Steering wheels wearing out.
Where do they rust if they are going to? Round the tail gate?
What else is there to look out for if i go to look at one?
Thanks!
Old Jun 6, 2010 | 09:07 PM
Kverna's Avatar
Kverna
Virgin-popper
Seen cooling problems too. As the cars don't got a temp gauge you'll find it hard to tell when the car's running hot. Only got a lamp going on if the cars overheated
Old Jun 7, 2010 | 06:47 PM
RichieST's Avatar
RichieST
Under door mirrors, boot handle can rub on bootlid wearing through paint, along bottom of doors and bootlid....
Make sure the cuttle panel is fitted tight against the windcreen or it will leak water into the passenger footwell!
Old Jun 13, 2010 | 12:41 PM
misty's Avatar
misty
Charge cooler pumps can be repaired in 30 mins by anyone with a soldering iron. Brushes off e-bay £5.00.
Small steel coolant pipe under drivers wheel arch (very common) £40.00 from ford.
Water pumps. If this is going or gone then short of having it re-built, it will mean VOR cuss there are none in the country, and no time given as to when there will be!!
Dave
Old Jun 13, 2010 | 07:53 PM
rstdave's Avatar
rstdave
Dave
The water pumps.....you say there are none available but they're not even that old lol, have they stopped producing them or something? Sounds like a bloody nightmare if they're really that hard to come by!
Old Jun 13, 2010 | 08:09 PM
misty's Avatar
misty
Rs specific pumps. None in the country.
Dave
Old Jun 13, 2010 | 08:51 PM
rstdave's Avatar
rstdave
That doesn't sound good.....would be a total cunt to have a 7 year old car rendered useless because you couldn't get a part for it!
Old Jul 8, 2012 | 02:54 PM
moleman23's Avatar
moleman23
newby
Default charge cooler pump brushes
bit of a long shot as the thread is from a while back but does anyone know where to get the brushes for the charge cooler pumps? ive searched everywhere and all ive managed to find was someone saying they modified a set of an alternator, any ideas?
Old Jul 8, 2012 | 02:59 PM
pee vee's Avatar
pee vee
http://www.ebay.co.uk/itm/AC7-CAV-AL...item19bbcb8804
and how to fit them
http://www.rsownersclub.co.uk/rsocbb...d.php?t=282115
thats about as close as (i think) people have found to a proper replacement set.
Old Jul 8, 2012 | 03:05 PM
moleman23's Avatar
moleman23
newby
yeah that is the set i found on another thread, thanks! mines working intermittently at the moment so needs sorting asap, cheers
Old Sep 23, 2012 | 05:59 PM
robbo_503's Avatar
robbo_503
I went to look at an RS today and couldnt see a stream of water in the charge cooler resevoir, I see its an easy enough fix but was wondering how worried I should be about whether its not been working for a little while? could this have damaged the car?
Old Sep 23, 2012 | 07:07 PM
AJC's Avatar
AJC
Check bottom of doors for rust
AJC's Avatar
AJC
On the inside that is
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
