st170 warning lights
Old May 31, 2010 | 10:24 PM
mac82's Avatar
mac82
Default st170 warning lights
hi all,
I bought a 52 plate st170 3 weeks ago, it has high miles but very well serviced, last service less than 1000 miles ago.
Took it on its first decent motorway run this weekend, from where I live, near chester-le-street to oakham, about 180miles.
Got there fine, steady 70>85mph, 50mph through the roadworks lol, used half a tank.
Headed back tonight, same speeds about 70>85mph. We stopped at weatherby services for some food and to top the tank up. While we were there a warning light came on, bottom left, orange with a pic of an engine in it.
It stayed on, drove home from there all be it a bit slower, about 80ish miles from home. Everything seems normal tho, all gauges reading within normal limits.
Any ideas?
Cheers Liam
Old Jun 1, 2010 | 06:24 AM
scortpower's Avatar
scortpower
disconnect the battery for ten mins, i had a similar thing happen on mine. took battery off then the light went out. got a mate to check it on the computer to see if everything were ok after to be safe,
Old Jun 1, 2010 | 07:15 AM
rsfido_1989's Avatar
rsfido_1989
needs a code reader, where you based mate?
Old Jun 1, 2010 | 11:05 AM
mac82's Avatar
mac82
I'm near chester-le-street, about 10 miles from Newcastle.
Will try the battery later, just its pissing down atm lol
Old Jun 1, 2010 | 02:38 PM
RichieST's Avatar
RichieST
Yeah disconnect the negative lead off the battery for half hour or so, then put it back see if the light re-appears. Chances are you lambda sensor is knackered, very common to go on the st170s, had to replace mine!
Old Jun 1, 2010 | 08:51 PM
mac82's Avatar
mac82
cheers rich, if it is the lambda sensor, will it need changing asap? or will it be ok for a while? im not doin much driving atm as ive just lost my job, and cant really afford to repair it right now.
cheers
Old Jun 1, 2010 | 09:56 PM
RichieST's Avatar
RichieST
Mine was knackered for a while, the light kept coming on and off every now and then. Will affect fuel economy a bit and drove a bit smoother after is was changed!
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
