anyone that know's EFI rs turbo blocks, can you help me?
Old May 26, 2010 | 08:04 PM
andy130's Avatar
andy130
Default anyone that know's EFI rs turbo blocks, can you help me?
iv got two blocks sitting in the shed, one has Q stamp on each of the main caps other block has F stamp on the main caps, could this mean one of the isnt a turbo block? or is it like that on eack rst efi block?
cheers andy
Old May 26, 2010 | 08:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I dont know the answer mate but I do know it's fine to use a NA block or a turbo block, i'm using a NA block and just drilled the oil return hole.
I went this route because NA blocks with good bores are easier to find and will never have seen the sort of temps that a turbo block has and so have a better chance of not cracking and lasting longer
Old May 26, 2010 | 08:26 PM
andy130's Avatar
andy130
very true, another thing is can i use my standard grind crank in a another block? that doesnt need boring?
Old May 26, 2010 | 09:37 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I wouldn't use another crank in there personally unless the block had been line-bored.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
nicos#29
17
Sep 7, 2015 05:32 AM
s1turboman
Aug 29, 2015 04:27 PM
marky_g
Aug 15, 2015 10:43 AM
