Engine management question
Old May 26, 2010 | 07:53 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Question Engine management question
After getting the general consensus that cossie management isnt the way to go have been doing some research and have decided to go with Emerald.
Now I know you need to purchase/fit the following parts to do cossie management.
2 Bar MAP Sensor
'Yellow' Injectors
Cosworth Ignition Amplifier
Cosworth Ignition Amplifier Heatsink
Cosworth Water Temperature Sensor
Cosworth Air Charge Sensor (ACT)
Cosworth Idle Speed Control Valve
1.8 CVH OR XR2i/FRST 1.6CVH Crank Sensor
1.8 CVH Crank Sensor bracket
1.8 CVH Alternator pulley and bracket
1.8 CVH Crankshaft pulley and bracket
1.8 CVH Crankshaft pointer ring and bracket
But the question is do i need to purchase/fit these or different items for Emerald.
There is loads of info around about doing cossie, but hardly any about Emerald.
Thanks
Barney
Old May 26, 2010 | 08:16 AM
studabear's Avatar
studabear
my guess is you will still need at least a complete efi inlet manifold, a coil pack and bracket, some form of crank position sensor and pick up, be it on the flywheel or crank pulley, suitable injectors
Probably best asking whoever supplies the emarald
Old May 26, 2010 | 08:17 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
You better go away and do some more research mate. Emerald over any other management system is not a good choice imo.
Couple of facts first.. All the trigger items and sensors that you will need for emerald you will need for cossie. So the price you will pay for emerald is more to start with as the loom and ecu will cost more! Then you will need to take it to someone who will map it. That will cost another 500 quid so what a waste of money when you could have weber running better than emerald could and for far less money. Seams silly to me. Why not speak with some people who have had emerald and removed it to fit better systems.
Old May 26, 2010 | 09:03 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Cheers Jano.
I was only going on what other people have advised, as like most thing everyone has got thier own point of view. So what management would you suggest then?
Don't want to go for silly BHP just what the car to run decent BHP and lose the MFI issues.
cheers
Old May 26, 2010 | 10:39 AM
homer j's Avatar
homer j
just out of interest who is it that has advised against weber? if you want proof as to how well it works just take a look at the results the nms cars have had on it. just because it's twenty years old does not make it shit. for what you want weber is the way i'd go mate. fit all new sensors, get a brand new loom form ryan and away you go. it'll be as good and reliable as any other efi system and it has the advantage of having easy access to replacement sensors etc. i'll be running weber when my rst is built back up and i'll probably only change when i put in an st170 turbo engine and the only reason for that'll be so i can run gucci shit like vvt to keep the response there.
Old May 26, 2010 | 11:47 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Homer,
I have been asking general questions over the last couple of months to friends, family and also tuners and the general thought is yeah cossie management is good but getting a little dated now and there are easier ecu's out there to install and tune.
Also a close friend of my brother in laws owns Redline Tuning and i have seen what difference emerald can make over standard(ish) ecu's and liked what i saw.
Thats how i've come to my decission, but like i've said above if anyone can suggest anything different then please let me know i'm open to any suggestions.
Also as Jano said above if anyone does have a Emerald K3 ecu for sale or knows of someone that might have one they dont want can you please let me know.
cheers
Barney
Old May 26, 2010 | 11:58 AM
1223456's Avatar
1223456
In regards to the emerald give them a ring direct ans speak to dave walker humself, very helpful chap.
What engine are you running at the mo?
Old May 26, 2010 | 12:19 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
At the mo pretty much standard apart from 195 chip, Kent cam. Just want to get away from mfi.
I'll give Dave a bell.
cheers
Old May 26, 2010 | 12:22 PM
jonny s2's Avatar
jonny s2
there are loadsa ecu's managements to choose from all do the similar job, i believe streetracers tune emerald with great results also
Old May 26, 2010 | 12:47 PM
mobb-black's Avatar
mobb-black
i've seen impressive results on both setups, i guess its preference, but my friends all swear by pectel
Old May 26, 2010 | 12:59 PM
conor.rst's Avatar
conor.rst
Why is cossie managemnt not the way to go ?
Old May 26, 2010 | 01:12 PM
Rob_DOHC's Avatar
Rob_DOHC
I would personally go with cossy management if i wasn't going to set the car up my self. agreed its by no means new but ford would have spent 10 maybe 100 times what emerald did in development and testing. You will nearly never beat an oem ecu for drivability plus there are countless tuners who can easily map the weber gear. Have a chat with MSD about their wated spark, closed loop and launch control boards.
If you were mapping it your self i would suggest nothing other than megasquirt.
Im not slating emerald, omex, pectel etc. Just making an observation over development of the systems.
Rob,
Old May 26, 2010 | 02:30 PM
Karlos G's Avatar
Karlos G
Balls Deep!
This is the easiest question to answer and it still gets regularly asked! lol
Choose what ever management your tuner is most familair with, as he will get the best results with it
Or as Rob says if you are fitting and mapping it yourself then go with Megasquirt as there are a lot of us on here that can help you with it!
Old May 26, 2010 | 04:25 PM
conor.rst's Avatar
conor.rst
Most of the parts for cossy managment you can still get new or even have made for you ...
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
