Need help!! Oil light on.
Old May 25, 2010 | 10:09 AM
Daniel Clement rs turbo's Avatar
Exclamation Need help!! Oil light on.
Hi lads, I've just put a engine into my frst, doesn't seem to hold oil pressure, oil light came on wen I started da car, it said it's about 11psi on da gauge at max and wen I rev it it goes up to 25psi maybe more and the oil light goes off, took the oil feed off the turbo and it just splutered out oil.. I've put a oil cooler kit on too and hav made sure to keep the air locks out.. Does anyone have any tips that will help me find out what the problem is, p.s. It seems to pump oil fine as checked it for that.. Thanks lads..
Old May 25, 2010 | 12:17 PM
stevo123's Avatar
stevo123
Either your guage or the pressure switch is lying. Try another oil pressure switch becasue your guage (seems) to be working akthough the idle pressure is a little lower than I would like.
Old May 25, 2010 | 07:18 PM
The two of them work together coz when it at 11psi the light comes on, but when I rev her it goes up to 30 and the light goes off, the normal switch worked fine on the old engine and the gauge never went below 32psi I think, would the oil pump not be good enuf for the oil cooler kit.. The pipes are very big too.. I have the gauge on the remote oil filter and the light on the dash goes onto the the T that comes out of the block to the turbo.. Haven't a clue what's going on.
Old May 26, 2010 | 01:22 PM
stevo123's Avatar
stevo123
Maybe if the pipes are very wide then the pump will not be able to move enough fluid to maintain pressure. Can you look at a good quality high capacity pump or maybe the piping on the oil cooler could be changed?
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
