Map Sensor Fault Question
Old Jan 16, 2005 | 09:36 AM
davidnormanuk's Avatar
davidnormanuk
Default Map Sensor Fault Question
Hi all,
Took my car to Well Lane Turbos yesterday to get it set up properly with the chipped ECU. Found out that the Map Sensor on the ECU is faulty.
I have a Series 1 ECU that has a working Map Sensor in it. Can i swap the sensors over by soldering it on?
Hope someone can help.
Dave
Old Jan 16, 2005 | 09:47 AM
AKRS1's Avatar
AKRS1
whats the exact fault
Old Jan 16, 2005 | 10:01 AM
davidnormanuk
The timing is not advancing as it should be. On tickover the timing is at 4 degress BTDC and doesn't advance much at all to about 10 if that. I have looked at the Map Sensor on a S1 ECU and it looks the same but has a different part number on it. I wondered if these are set the same or do they work at totally different pressures.
Old Jan 16, 2005 | 10:34 PM
GrimmeRS2K's Avatar
GrimmeRS2K
buy another series 2 ecu, they only about a tenner, and solder the chip into that one.
Old Jan 16, 2005 | 11:24 PM
DazC's Avatar
DazC
Or just use the S1 ECU. Most consider the S1 ECU better as it doesn't have a knock sensor.
Old Jan 17, 2005 | 01:31 PM
davidnormanuk
Does anyone know the differences between the series 2 ecu and the series 1 apart from it not having the knock sensor?
Old Jan 17, 2005 | 08:42 PM
DazC's Avatar
DazC
Not exactly sure.
Try asking in the general section. Not everyone comes in here.
Old Mar 16, 2005 | 08:21 PM
AKRS1's Avatar
AKRS1
I know this is an old thread but i now have the same problem too. Does anyone know if this causes the car to hesitate at around 3500rpm
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
tib2220
Sep 14, 2015 12:33 PM
Si B
Sep 12, 2015 06:49 AM
