AB07 Cam
Old May 22, 2010 | 08:55 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default AB07 Cam
Im thinking of upgrading to one
Does anybody have one of theses cams fitted on the inlet side ?
Any information about how it drives, makes power would be nice
Steve
Old May 22, 2010 | 10:58 AM
Sonic Boom's Avatar
Sonic Boom
Looks very simaler to a BD14 execpt you can use them with out any need for piston pocketing.
Rich
Old May 22, 2010 | 11:12 AM
D16PJM's Avatar
D16PJM
your not spending more money on it surely.
I wonder if this is going to turn into a 15 pager like your last one.
Old May 22, 2010 | 11:21 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Bit slow so far Pete
Did you get my PM ?
Steve
Old May 22, 2010 | 08:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Nobody know anything then
Steve
Old May 23, 2010 | 05:11 AM
LINCOLN's Avatar
LINCOLN
Only "heard" he picked up 20-30bhp over standard exhaust cam when in a bd16+ inlet t4 480bhp combo.
Not much help to you though.
Old May 23, 2010 | 02:28 PM
BRAMMER's Avatar
BRAMMER
Steve
I'm getting a pair (after my next mod to increase power) - don't forget your double valve springs
Old May 23, 2010 | 02:31 PM
Are they hydraulic cams or not ?
Old May 24, 2010 | 09:04 AM
joffy's Avatar
joffy
SLOW LEARNER
would like to know more aswell, is it worth having a pair or just the inlet because everyone seems to say keep the standard exhaust cam up to 500bhp??
Old May 24, 2010 | 06:28 PM
BRAMMER's Avatar
BRAMMER
hydraulic cam - requires double valve springs
Old May 24, 2010 | 07:35 PM
This one mentioned requires double valve springs ? and is hydraulic, okey dokey, not heard of that particular one myself.
What's it nearest to in BD terms ?
Old May 24, 2010 | 08:49 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Nearest that i can see looking at the figures is a BD14
Steve
Old May 24, 2010 | 09:07 PM
Thanks,
Old May 25, 2010 | 02:10 PM
Nash's Avatar
Nash
Cake lover!
I run that cam in my car and have done for 3 years. Think the other name for it is CW1.
Old May 25, 2010 | 02:16 PM
joffy's Avatar
joffy
SLOW LEARNER
what other mods are you running and whats your view on it?? are you just running the inlet of exhaust aswell??
Old May 25, 2010 | 02:27 PM
Nash's Avatar
Nash
Cake lover!
I am just running the Inlet with a standard exhaust, the car defo drives better than it did before, feels like it comes on boost earlier and holds the power right the way through. I did go from L6 ecu with an off the shelf chip to L8 ecu and live map at the same time.
Standard valve springs, mildly ported head.
The was the car on a DD dyno last year, high and low boost graphs. The boost ppipe blew off on the high boost run due to me splitting one the day before and having to bodge one on for the day.
Old May 25, 2010 | 06:07 PM
I think most run the std exhaust with a BD 14/15 type cam with very good results.
Old May 25, 2010 | 06:36 PM
BRAMMER's Avatar
BRAMMER
I'm going to price an inlet cam up tomorrow, do all Kent stockest sell them or are they only available from selected outlets??
Old May 25, 2010 | 08:24 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I haven't found out yet.
What other mods are you doing ?
Steve
Old May 25, 2010 | 08:26 PM
Nash's Avatar
Nash
Cake lover!
If you Talk to Rainbird or Grove garage they will defo be able to sort it for you.
Old May 25, 2010 | 08:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What boost are you running on yours ?
You are on a T38 as well i think ?????
Steve
Old May 25, 2010 | 09:02 PM
Nash's Avatar
Nash
Cake lover!
Steve mine runs 28psi held on a T4 mate not a T38.
I had my cam off Ahmed directly when he mapped the car i got him to install it.
Old May 26, 2010 | 03:38 AM
BRAMMER's Avatar
BRAMMER
Steve my top end will be complete with a new inlet cam and double springs, I have the 4x4 inlet and 17.6mm spacer is fine and ports are 25/26. My bottom end has under 3k since build
Old May 26, 2010 | 07:35 AM
joffy's Avatar
joffy
SLOW LEARNER
can we get 5 or so together and do a group buy??
Old May 26, 2010 | 07:54 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Do u want me to ring Grove and get a price
joffy's Avatar
joffy
SLOW LEARNER
sounds like a plan,
Old May 26, 2010 | 11:03 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Does anybody know what the lift and duration is on the standard cam ?
I have the figures for the AB07
Steve
Old May 26, 2010 | 11:15 AM
joffy's Avatar
joffy
SLOW LEARNER
8.5mm and 241 degrees i think
Old May 26, 2010 | 11:17 AM
joffy's Avatar
joffy
SLOW LEARNER
dont quote me on that though
Old May 26, 2010 | 11:28 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The AB07 is 8.85mm and 256 degrees
So not that much extra lift but 15 degrees more duration
Steve
Old May 26, 2010 | 11:32 AM
joffy's Avatar
joffy
SLOW LEARNER
sort of a BD13 then, halfway between a 12 and 14 in lift
Old May 26, 2010 | 11:40 AM
There may be enough meat on the std cam for a regrind(to BD14/15) ?, does anyone know for sure ?
Old May 26, 2010 | 12:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Phone Kent or Piper and ask them, im sure they would be the best people to talk too
Steve
Old May 26, 2010 | 12:13 PM
joffy's Avatar
joffy
SLOW LEARNER
whats the score with regrinds, are they as good as new or just a more economical alternative??
Old May 26, 2010 | 02:36 PM
BRAMMER's Avatar
BRAMMER
Saves me a call Pete
I see Stu's knocking the double valve springs (no mods) out at Ł144 posted maybe he'll have a little site group buy if enough were interested or would you just buy the one side for the high lift cam??
http://cgi.ebay.co.uk/RS-Cosworth-YB...item41494743c5
Old May 26, 2010 | 02:44 PM
pete mcrash
Steve
..........from what i was told it has more lift and less duration so it's not as laggy..........
need to know how many cams, and what price they are to buy from Kent/burtons...then i'll ring back and see if Ahmed can sort something out...Mark at grove says they do work well,but to get the most out of them u need a ported head
Old May 26, 2010 | 02:45 PM
pete mcrash
dont need them with the AB cam....
Old May 26, 2010 | 03:08 PM
joffy's Avatar
joffy
SLOW LEARNER
il be interested in a group buy or maybe just on its own if no one lese is interested? think ported head would be my next mod anyway, is there any advantage of the double valve springs anyway even if they are not 'needed'
Old May 26, 2010 | 03:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
I am happy to run group buys on any items you guys are interested in that we sell.
Old May 26, 2010 | 03:25 PM
joffy's Avatar
joffy
SLOW LEARNER
Stu any answer to the question above as ive been thinkin of purchasing for a while now??
