AB07 Cam
#41
..........from what i was told it has more lift and less duration so it's not as laggy..........
need to know how many cams, and what price they are to buy from Kent/burtons...then i'll ring back and see if Ahmed can sort something out...Mark at grove says they do work well,but to get the most out of them u need a ported head
I have a ported head
Steve
#47
Cake lover!
Pete i have never seen worse than 11:8 AFR under full throttle and thats even when it holds 30psi loaded up in 4th/5th up a hill. Then it will sit at 16:1 AFR when cruising/part throttle at 90mph in 5th.
Taking my car all that way to get Ahmed to map it was the best thing i ever did, if i never go for more power i will go on to T2 and drive it back down again to him even if i have to wait 3months to get a mapping slot.
#48
saff is working!!!...atm
#49
I can get a regrind for Ł60 to whatever spec from my machinists, used these on my pinto and x flow as well as celica, a series(x3) never had a issue with wear on any.
#50
I already have modded head, hopefully raising CR to nearer 8.5 at same time, maybe even higher if I'm lucky.
#52
Cake lover!
Your best off giving them a ring and asking the question, i had alot done at the time of getting it mapped [suspension work, cam, swapping ECU] so cant remember the definite price just for the mapping. They arent mega expensive though.
#55
A decent mapping session makes a world of difference to a off the shelf chip, best thing I ever did as well, luckily for me my mapper is about 1/4 mile away, but I'd have travelled the whole length of the country to get dave to do it also, well worth it.
I reckon you would be better off just saving for all the bits/mods you want, doing them then just get it mapped by whoever you want, don't let distance dictate this.
#56
Doent seem to bad, Did you mention to Kent cams about a group buy?? or can we just send two as a 'pair' even if they are both inlets as i would want to keep the standard exhaust cam??
#62
....first time u go it'll be more as u buy the chip n pectel board and the car is live mapped but it was around Ł400......then every time/year u go back and they check ur car over and take it out and "tweek" it, it costs alot less...think last time it cost about Ł250.....
#63
Where I go it's the same price, Ł275 for all three maps, however long it takes, be it an hour or two days, a simple check if you wanted to check power/AFR would be around Ł40-Ł50.
Every single aspect of the car is touched even realigning the cam timing if not correct, if the op feels it should be more power, or something else is wrong.
#65
You do lose some base circle, but the hydraulic tappet expands to take this up, just the same as it does when new, we are only talking a very small amount in tappet terms.
I used pinto regrinds for around 8 years, they are quite hard on cams but never an issue.
#71
ive never atchualy herd of a 205 block shitting itself, yet you hear about 200 blocks cracking fairly often...
maybe its beacuse no one dares push the 205 block that far, im on a similar spec to steve and dont worry in the slightest
#74
I realise the thread has shifted slightly to the block now, but that's a good question. I'm upping my set up to between 400 and 450bhp - do I need to change to a 200 block? What are the dangers of not doing so? I'm thinking that upgrading the cooling etc would be enough to keep temps down?
