S2 not boosting at all!!!!???
Old May 17, 2010 | 03:43 PM
mattseries2's Avatar
mattseries2
Default S2 not boosting at all!!!!???
Hi Guys!
Having a little trouble with my scort!
Couple of months back i had a little front ender not serious only cracked the bumper and done the rad... ive oviously changed the rad (ally) and i got new boost hoses (old ones looked tatty) and now she wont boost up at all! Its like driving a n/a 1600. I know it could have been coincidence but i changed the ovious like plugs leads and brought a grp a coil. After closer inspection i saw a small hairline crack on the exhaust manifold and it was blowing... therefore i thought thats the reason its no boosting, but ive now replaced this and still now joy!
Anyone got any ideas what it could be?
CheeRS
Matt
Old May 17, 2010 | 03:48 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Is there a leak on the intercooler.
Old May 17, 2010 | 03:52 PM
mattseries2
I did give this a good look over when stripped out...couldnt see any visable cracks? I think ill pressure test it. Whats the best way to do this?
Old May 17, 2010 | 04:01 PM
danb21t's Avatar
danb21t
fill it with water
Old May 17, 2010 | 04:08 PM
Versus_Creations
Ask me a question!
no not with water. Its got loads of oil init and it wont like loads of water being dumped in there for no reason.
The best way would be to put an air line into the boost pipe and seal it best you can. I normally use a hard plastic cup which fits into the boost pipe with a trye valve on top. I just listen for air leaks and use water with fairy liquid and squrit some if i think there is a leak, if so bubbles will appear from the leaking air.
If you have an MFi system then its unlikely that its an air leak as it wouldnt run very nice at all if it did at all. Unless its been molested to run with the air leak.
Is the actuator connected and the pipes all ok with no splits etc.
Old May 17, 2010 | 04:13 PM
mattseries2
Its still running on MFI yes and its idles and runs fine. Yeh double checked everything, Brand new boost hoses, ive check all actuator pipes etc and its connected.
Starting to confuse me now...
Old May 17, 2010 | 04:15 PM
Versus_Creations
Ask me a question!
maybe the shunt on the rad hit the actuator and split the side of it?
Old May 17, 2010 | 04:16 PM
Versus_Creations
Ask me a question!
need to check it like i described in a similar post about 10 mins ago to karlos g.
Old May 17, 2010 | 04:21 PM
mattseries2
Ill check that after the fmic then. Its not a std actuator its alot bigger and is made from billet ally, has a universal turbos sticker on it, any idea?
Old May 17, 2010 | 04:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could also be the penny is stuck after the impact, i've seen this recently myself on another car.
Old May 17, 2010 | 04:37 PM
mattseries2
Sorry Karlos could you explain?
Old May 17, 2010 | 04:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Inside the exhaust housing there is a penny wheel, this is what the actuator rod opens and closes to control the gas flow, if it's stuck open then you will get no boost.
Old May 17, 2010 | 04:53 PM
mattseries2
Ok mate ta. And what if it is stuck open? What needs to be changed?
Old May 17, 2010 | 05:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
TBH I dont know! lol
Looking at the picture the turbo would need to be sent away for repair I would guess.
Old May 18, 2010 | 12:20 AM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
That picture dont look like its from an rst, the wastegate penny is located in the removable cast that the downpipe bolts onto, which dont involve sending the turbo off as that will cost you a packet, but you will most probably need to use oxy blow torch to heat up the nuts as they will most defo break the studs if you try to remove the wategate housing without heat. if you need a new wategate cast i got 2 here PM me if your interested
Old May 18, 2010 | 07:07 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It isnt from a RST T3, was just a generic pic to show what I meant mate.
Old May 18, 2010 | 08:01 AM
conor.rst's Avatar
conor.rst
may sound obviouse but you hae et the actuator up properly with abit of preload on the spring etc .....
Old May 20, 2010 | 05:08 PM
mattseries2
i havent touched the actuator ive only taken the elbow off to check everything was ok, wastegate was shut and all looks fine.
Thats why i find it weird, it drives like a n/a engine not boost at all!
Surly if it was a split hose or anything it would still try and boost and just hiss?
Anyone got any ideas?
Old May 21, 2010 | 08:28 AM
Versus_Creations
Ask me a question!
is the compressor wheel still in good condition.
Old May 21, 2010 | 02:53 PM
RSTurboSI's Avatar
RSTurboSI
check your timming, MFI leaks.
you may think, eh.. but RSTurbo MFI engines always, always play up. could be fine one day, the following it could not boost, or run, or whatever. but should if done correctly.
as most have said and MrOddkid.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
