Ka 2.0 ecu wiring info.
Old May 9, 2010 | 03:03 PM
flatcap's Avatar
flatcap
Default Ka 2.0 ecu wiring info.
Hi there,only last week,have sucsessfully wired in a dewy ecu from mondeo into my 2001 ka.if anyone needs any help let me know happy to help.
Old May 11, 2010 | 06:58 PM
lower's Avatar
lower
fella will need your help soon. just need to sort an altinator bracket.
Brad
Old May 12, 2010 | 07:11 PM
flatcap's Avatar
flatcap
Brad
yeah no sweat,i got mondeo and ka haynes manuals,made two lists 1 to 60.for each pin location on ecu of each car and cross referenced them.easy really.then just swap pins over.there is a lot of wires not used,these are mostly air con and pats.i also used the engine loom from ka,you will have to unwrap some wires to get them in right positions.lengthen coolant sensor plug.depending on year of ka,you might have to wire in air flow meter and air temp sensor.straight to ecu,if you have t-map sensor.like i say,happy to help,will write out guide on what to do and pin locations,very soon.
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
nico12
Dec 31, 2015 04:42 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
