Stereo head Unit
My Sapphire has the original stereo and speakers. I want to upgrade to a new head-unit and speakers but I am hoping to leave in place and re-use the original wiring to the speakers. I am looking at Blaupunkt or Kenwood head-units with black face plates that hopefully won't look out of place.
First question: will the original wiring connections / plugs fit with a new head-unit. If not are there adaptors available or do I have to cut off the original plugs and use new ones?
Second question: what happens to the fader and bias controls for the original unit? Do you leave them in place or simply remove them from the circuit?
Gary Krishna
You can get adapter looms to convert the wiring to fit the radio of your choice.
I used Autoleads ones in my old sierra and my cossie.
There are 2 different kinds of adaptor looms. One for the amp under the head unit and a longer one for the types where the amp is in the n/s/f footwell.
I assume yours is the first one.
When you have fitted the new head unit, the amp below will already be disconnected so just leave as it is!
Job done!
Job done!
Job done!
Job done!
I went to the Autoleads site; so basically I need is one of these for the headunit?
http://productfinder.autoleads.co.uk...d=522&pID=7804
Gary Krishna
Thanks. My car is a 1988 2WD Sapphire that has the amp with the fader / balance knobs immediately below the head unit.
Get one of those, plug it in, connect your new radio and off you go.
You'll probably need an aerial adapter as well though.
I contacted Autoleads; here is their rather unhelpful response:
"You will need to find a local car audio specialist who stocks Autoleads products. However I’m afraid that we currently don’t have a PC9 lead that fits your vehicle."
As you can imagine, there aren't any Autoleads stockists in Australia; and, even if there were, they wouldn't have a Sierra loom because the car wasn't sold here.
Back to the drawing board, unless there is kind a PassionForder who is willing try and track one down for me in the UK.
Mc5506
Oct 5, 2015 09:57 PM
