ib5 gearbox help please
Old May 7, 2010 | 08:12 PM
RSargie's Avatar
RSargie
Default ib5 gearbox help please
hi all was going to fit my ib5 today but forgot to ask anybody about what clutch cover can i use, can i use the standard rs one? or do i need the one for a later escort which has an ib5, obviously i have to use a ib5 release bearing which is differant to a rst one.
any help would be great cos i just wanna get it sorted thanks.
Old May 7, 2010 | 09:25 PM
isaac james sherwood's Avatar
area six 2.1 zvh ford ka
Hi buddy i have fitted an rs turbo 220mm clutch and just used the i b5 release bearing and this has worked fine buddy!
Old May 7, 2010 | 09:55 PM
gtirossy's Avatar
gtirossy
I was going to fit an rs turbo clutch to my zetec but when it came to fitting it, i noticed that the two different release bearings act on different parts of the clutch mechanisms. It was about this time last yr but if i remember rightly, using the escort gti release bearing looked like it would provide less leaverage because of it being a wider diameter but the rs turbo one wouldn't fit over the input shaft cover thingy????? In the end i gave up and fitted a brand new escort gti clutch and bearing then ordered a luvly uprated gti clutch thru helix.
Old May 7, 2010 | 10:01 PM
RSargie's Avatar
RSargie
i noticed something similar today, the rst clutch when fitted has the fingers on the pressure plate completley flat, and the ib5 release bearing is flat so when it pushes the fingers it looks like the fingers will contact the bearing casing. so woundered it i should use a diferant cover, ill mabye just have to order 1 and have a look.
Old May 7, 2010 | 10:19 PM
Well it has worked fine on my 2.1 zvh ford ka with an ib5 gearbox and atb diff lads?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
