WHeel bolt size!
Old May 6, 2010 | 06:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default WHeel bolt size!
I noticed today that my Mondeo alloys are barely being held on by the wheel bolts (could almost pull through the holes in the wheels)!
I also realised that most Ford bolts are 19mm and my bolts are only 17mm, so I'm thinking the flanged part of the bolt will be bigger with 19mm and so fit the wheel better.
Has anyone else noticed that Mondeo wheels dont fit the bolts well, or is it just because my heads are 17mm and not 19mm?
The thread is obviously correct though
Cheers!
Old May 6, 2010 | 06:10 PM
phil_focus's Avatar
phil_focus
are you using ford wheel nuts as the ford ones are much bigger than aftermarket nuts???
Old May 6, 2010 | 06:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
They are not nuts mate they are bolts, and i'm using what came on the car so fuck knows! lol
Old May 6, 2010 | 06:14 PM
studabear's Avatar
studabear
Karlos speedshack sell the ones you need
Old May 6, 2010 | 08:09 PM
12_Second_rst's Avatar
12_Second_rst
You considered converting to studs karlos?
Old May 6, 2010 | 08:26 PM
bad boy rs's Avatar
bad boy rs
apparantly a special bolt is needed for these wheels and i bought miner at speed shack
Old May 6, 2010 | 08:31 PM
neil73's Avatar
neil73
As said above, speed shack sell em, it's the ghia bolts you need with the larger washer, just had to buy some for my rs 7's
Old May 6, 2010 | 08:40 PM
phil_focus's Avatar
phil_focus
a ford with bolts???
never knew that!!!
Old May 7, 2010 | 08:57 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Speed shack it is then! Cheers Fella's!
Old May 7, 2010 | 09:03 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The bolts you need, AFAIK, are what I know as a 'Ford Ghia' bolt. Like these.....
http://cgi.ebay.co.uk/FORD-GHIA-BOLT...item334d56df60
They are more abundantly available as a nut though.
Old May 7, 2010 | 09:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Ahh sweet!
I'll try my local motorfactors first, if not Speedshack!
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
borboyous
Aug 22, 2015 11:17 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Bosch
Aug 4, 2015 05:14 PM
