zetec ecu wiring
Old May 5, 2010 | 07:39 PM
martin12's Avatar
martin12
Default zetec ecu wiring
Have just fitted a 1800 zetec into my kit car, running on twin40 webers, need to wire the ecu to run ignition system, have original key ecu & transponder, has any one successfully done this, if so do you have a wiring diagram. Thanks Martin.
Old May 5, 2010 | 07:43 PM
D16PJM's Avatar
D16PJM
don't know about original ecu but you can get a mega jolt ecu and wiring for a couple of hundred quid.
Old May 6, 2010 | 10:39 AM
sonic7's Avatar
sonic7
Dont think it can be done as d16pjm says as closed loop for fuel / emissions etc would probably put engine in limp home mode.But if you still want to try, look for ford tis cd on ebay they are usually about a fiver and include a range of engines especially zetecs
JK12
33
Apr 26, 2021 12:09 PM
Tank Mike
Sep 14, 2015 03:56 PM
ward1174
Sep 12, 2015 03:34 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
