air con problem can you help
Old May 5, 2010 | 09:46 AM
karlos09's Avatar
karlos09
Default air con problem can you help
hi can you help me , when i put my blower on my air con klicks on as well even though it is switched off, i can ear the rad fan come on as well could this be a switch or sensor iv had to pull out the relay from keeping the air con from kicking in cheers
Old May 5, 2010 | 05:16 PM
martysmartie's Avatar
martysmartie
Is this a Focus by any chance and is it in at all blower speeds? If only when the blower is in position 3 the A/C will be on regardless, the same applies if the heat direction control is on windscreen but regardless of blower position.
Martin
Old May 5, 2010 | 08:31 PM
karlos09's Avatar
karlos09
hi martin ,yes it is a focus 2001 ,if i was to turn the blower on to no1 postion with in 2 seconds you would ear the air con pump kick ,and also the fan to the rad come on weather the heater control is in the hot or cold postion ,you dont even have to touch the air con switch cheers karl
Old May 5, 2010 | 09:12 PM
martysmartie
Do you have it set for full heat?
Martin
Old May 6, 2010 | 06:14 AM
karlos09's Avatar
karlos09
at the time, yes it was on full heat ,cheers karl
Old May 6, 2010 | 12:27 PM
martysmartie
Try turning it down a bit as full heat also does something with A/C.
Martin
S3an
Sep 26, 2015 11:39 PM
Flateric_2002
Sep 15, 2015 08:41 AM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
markk
Sep 9, 2015 08:11 AM
