engine and gearbox removal
Old May 2, 2010 | 02:54 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default engine and gearbox removal
as above do i basically undo engine and gearbox mounts, and undo pipes and wires and lift out?
Old May 2, 2010 | 03:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Pretty much yes!
danzul's Avatar
danzul
disconnect the drive shafts, or prop, and then yeah pretty much, just take time and be methodical about it, checking things as you go so u dont leave anything conected between the car and the engine,
Old May 2, 2010 | 03:59 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
if ya can drop it out the bottom
Old May 2, 2010 | 09:15 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
As above, drop the engine out rather than lift. Much easier and you can leave suspension, drive shafts etc in place.
Using an engine cradle, lift off mounts and onto jack, chocked up with wood, release cradle and use it to lift the front end of the car up enough for you to pull the engine out. Job done
Old May 2, 2010 | 11:00 PM
gingerturbo
oh well done my bad should of said more than just drop out bottom
SmudgerByName
52
Jul 28, 2016 06:14 PM
CLIVE
Oct 2, 2015 12:58 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
