Wasted Spark ?
Old Apr 30, 2010 | 09:10 PM
mattman1234's Avatar
mattman1234
Default Wasted Spark ?
How efficient is wasted spark,does it draw more,or less current than a group "a" coil.Is wasted spark supplied through the ecu,or does it have a separate loom that drives the coilpack.
thanks matt
Old Apr 30, 2010 | 09:14 PM
bad boy rs's Avatar
bad boy rs
very efficient mate, apparatly the best mod for a cossy although ive not done it myself yet. You will need a seperate driver board for l6 l8 to be fitted inside the ecu and also a fly loom to drive the extra ignition amp, ive herd jano is the cheapest for the whole kit
Old Apr 30, 2010 | 10:28 PM
Sonic Boom's Avatar
Sonic Boom
This is possibly the best mod you can do to Cossie, it's fitted to my 3 door as is brilliant.
Rich
Old Apr 30, 2010 | 10:30 PM
BJAS's Avatar
BJAS
MSD has a very good wasted spark kit.
Old Apr 30, 2010 | 10:39 PM
COLEYST200's Avatar
COLEYST200
iv got a MSD wasted spark on my car . i got it as a DIY kit very nice mod there is one or two down sides with the kit some times when i turn the key i will get a coth from the motor as all the plugs fire at the same time it will never start but it is funny . you will all so have to keep your spark plugs down to a small size on the gap like .65mm not wot you would think like a mondeo which runs over 1.00mm . all so the kit will some times play up with you rev counter and will need a small bit of we wiring to sort it if running a ford clock set up . the one big down side iv had is you have to mod the ECU for the wasted spark and put some new wires inside the ECU plug which mean if you need to test a new ECU on the car it wont work unless you revers the wiring back to standerd which is a pane in the ass . but at the same time when its working it works very well
Old Apr 30, 2010 | 11:12 PM
Nash's Avatar
Nash
Cake lover!
Its a good conversion but IMO if you dont stuffer from miss fires on a standard/grp A coil i wouldnt bother.
Old Apr 30, 2010 | 11:16 PM
col93saphcos's Avatar
col93saphcos
one of the best thing i did to mine,msd one,they fitted driver into ecu,so was really just plug and play,did need to modify tacho,full instructions and was easy enough to solder the wee loop wire in at the back of the tacho,seemingly not all need tacho modded,never miss fires in damp now,which it always did before unless sprayed wd40 on connections to group a coil and cap etc every other day,cars my daily driver
colin
Old May 1, 2010 | 06:04 PM
What he^^ says, apart from I think it is bloody expensive, though I've no doubt there was a lot of design/testing work etc gone into it which needs paying for, I just think the cost compared with aftermarket ecu is prohibitive, I only went coilpack as my ecu runs it direct, with no questionable reliability issues of any external amps.
Old May 2, 2010 | 12:36 AM
BRAMMER's Avatar
BRAMMER
I got it last year and never regretted, isn't that expensive really, i had the driver fitted by msd and bought the rest myself
Old May 2, 2010 | 09:03 AM
bad boy rs's Avatar
bad boy rs
is it cheaper to collect all the bits yourself ?
Old May 2, 2010 | 09:06 AM
retro d's Avatar
retro d
Good mod im doing this on my mk3 rwd.
Old May 2, 2010 | 09:18 AM
RS500/364's Avatar
RS500/364
Sure the wasted spark is for bigger gaps !
what the mod on the rev !
Old May 2, 2010 | 11:10 AM
With differing compression including adiabatic, this will alter how much spark you can get away with.
If you use a ACCEL coil in place of the early zetec type this gives around 40% more spark power, around Ł36.
Old May 2, 2010 | 11:12 AM
In the context of aftermarket ecu's that have it as std plus more it is pricey imo for one small part, aftermarket start at Ł350 including a loom from AS for example.
Old May 24, 2012 | 07:51 PM
musclecar340's Avatar
musclecar340
Sorry got a little Question.
I have bought me the MSD Wasted Spark Kit, but they forgot the instruction,
Can anybody send me a mail with the instruction?
christianwolf@chello.at
THX Chris from Austria
Old May 24, 2012 | 08:21 PM
Toe Knee's Avatar
Toe Knee
Why not ask them as I'm sure they would email them for you?!
Old May 25, 2012 | 04:39 AM
musclecar340
i did!!!!
Since one week i tried to get a answer.
Old May 25, 2012 | 02:44 PM
James @ M Developments.'s Avatar
Steve has been on holiday this week, so that may explain why you got no reply, if the email had directed to him.
i think ive caught up today, so hopefully this has been sorted now. if not let me know and i will fire them over to you.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
