bottom end
Depends on all sorts of variables like oil pressure, wear etc etc, a good estimate I would say is between 200 - 250 but tbh I dont really know. When I first built my fiesta the first time round it was with all standard internals and that was producing 200bhp @ 1bar. Never missed a beat.
Why do you ask?
Why do you ask?
Why do you ask?
Why do you ask?
Thanks for the info
The rods are the weak point, Cranks is good for 350bhp+, Pistons 300bhp, but the rods (or rod bolts) have been known to let go as low as 190bhp depending on how it's driven, lots of high revs for example will throw one sooner rather then later.
Yes pretty much, again it's a bit of pot luck with the rods themselves too, I supose it depends on how well they were cast, how many imperfections etc..
250bhp max with arp rod bolts, though as said it's not ideal as you can't be 100% sure how long it will last.....1bar of boost like you're planning on running should be fine as long as the engine has been built/mapped properly, i would have used arp rod bolts at least though.
If you read what ave wrote. A said a dont kno what c.r it has been lowered to
lol
power engineering said to me without even blinking,standard bottom take 250Bhp and no mention of arp parts.LOng as the engine built to high standards.Fresh engine,low miles.hope that helps.
trust what others have said here mate. a standard bottom end without arp rod bolts and running around 250bhp is a ticking time bomb. arp rod bolts are the absolute minimum.
Well if you can't trust a tuner who can you trust lol..Passionford
I personally would'nt risk running that power on standard bottom anyway.Never push it to the limit.Just asking for trouble.Ill be running around 210 / 220bhp max on standard bottom end this summer.Then forge her up.You think that safe enough?
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
