ecu output votages
Old Apr 20, 2010 | 09:52 PM
RSargie's Avatar
RSargie
Default ecu output votages
hi does anybody know what voltage the 2 ecu's send out to various engine sensors? i have quite alot of info but carnt find any what voltage should be coming out. and a few sensors from the fuel ecu have varying voltages.
8v to air flow and efpr
11.5v to throttle position
the live feed for the amal valve has melted, which gets a feed from the fp relay. but also feeds the coil and phase sensor which are ok and still have correct voltages. also fuel temp sensor feed is still ok and that comes from fp relay.
reason i ask my car is fueling its nuts of, to the point were its causing a misfire when on boost at about 5k revs. which sometimes takes a few seconds to come back on 4 cyl when you let off. but also if you keep your foot in you can sometimes drive through it.
now if you turn the boost up its less noticable cos theres more boost obviously, but it used be ok at a bar so shouldnt need to turn it up as it could run lean else were in the rev range.
took the plugs out today and there as black as the ace 0 spades.
all the engine sensors have the correct ressistance and 90% are new. ive tested all engine loom conections from sensor to ecu and the ressitance is 3ohms at the most on all conections so no prob there.
i have spare ecu's but they dont make a differance also i dont know if there any good?
anybody with any thaughts would be a great help other wise its a long trip to msd and an empty wallet thanks
Old Apr 21, 2010 | 10:43 AM
RSargie's Avatar
RSargie
some on must have some info???
Old Apr 21, 2010 | 08:27 PM
RSargie's Avatar
RSargie
antbody know some1 who can help with info online? so i dont have totake it somewere, thanks
Old Apr 21, 2010 | 09:47 PM
DazC's Avatar
DazC
Have you tried another ECU?
I've had an issue like this before on an RST and it was coolant temp sensor related. It was open circuit.
Disconnect the plug off the fuel pressure actuator on the metering unit and see what happens.
Old Apr 21, 2010 | 09:53 PM
RSargie's Avatar
RSargie
have treid another ecu and 2 new fuel temp sensors, although i have no garuntee the other ecu is working thus why i want to know output voltages as i have heard they can go wrong causing to high or to low voltages to sensors
Old Apr 29, 2010 | 05:03 PM
RSargie's Avatar
RSargie
bump!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
