fuel in boost pipe?
hey there i had my car set up at ava in glasgow all seemd fine but i had a t3/t4 turbo on, so i changed the turbo over to a t34 all seemd fine untill i went to change the amal valve to a boost controller and when i took the middle boost pipe( one from turbo to metering unit) fuel pished out the boost pipe??:S
why is this anyone any ideas? thanks
awright chrighton, T34 will prob still be a bit big for what you need, but aye as karlos sais the metering unit must be leaking somewhere, will either need stripped and fixed or replaced if the latter that would unfortunately involve another setup on the rollers
how was it going afterwards anyway? must have been night and day!
Thats pretty shit regardin the flywheel, glad it's sorted though !!
Yea it was fine before, but thats jus how it goes wi these cars, fine one minute fucked the next lol
Maybe strip the metering unit a bit and see if you can see anything wrong, probably a seal somewhere has burst
No idea on seal or where to get one mate, the setup shouldnt be affected unless it was leaking at all when it was setup, it needs to come apart either way to fix it so strip it and have a swatch!
If you got other metering unit's laying round, why don't you swap it? then safely drive to your tuner and then all they got to do is set the fueling up. So should'nt cost you as much as before.
Then if you wish you can strip and refurbish that metering unit while still being able to drive your rs.
back in 2009 cost me near 400quid but that included new actuator and chipping ecu and rolling road tuned. A normal rolling road set up without extra's should cost around 80quid an hour.
JK12
33
Apr 26, 2021 12:09 PM
