ford focus engine management
Old Apr 16, 2010 | 10:06 PM
alexwhitefoot's Avatar
alexwhitefoot
Default ford focus engine management
i have a ford focus 2001, i have the engine managment light that comes on, i took it to the garage they reset the light changed the lambert sensor but still comes on. i want to just turn it off can i do this without spending money
Old Apr 16, 2010 | 10:29 PM
Saaamon's Avatar
Saaamon
Can you not go back to the garage and ask them to check it out again for you. Was the lamba sensor at fault? I'm guess thats why the light was up before.
Old Apr 16, 2010 | 10:49 PM
alexwhitefoot
Question money
i have been to and from the garage the car itself is not playing up i just want to turn it off somehow so it doesnt go on
Old Apr 17, 2010 | 07:07 AM
Stevie-Boy's Avatar
Stevie-Boy
Gettin There
Hi mate get someone who has a Bluefin and it can be turned off.
There are also cheap devices on Ebay that will do the job.
Old Apr 17, 2010 | 07:53 AM
focusv8's Avatar
focusv8
If the light comes on you still have a fault somewhere, that's what the light is for it's a WARNING something is wrong.
Old Apr 17, 2010 | 10:10 AM
stevieturbo's Avatar
stevieturbo
C**t
Its amazing some people wouldnt guess that !!
Simple fix for people like that....just remove the bulb. The car will never have a fault again
Old Apr 17, 2010 | 10:37 AM
rsfido_1989's Avatar
rsfido_1989
had mine on, got bluefin for fault reader and was o2 sensors changed them both and gotta remap with decat now so happy with my outcome.
Old Apr 17, 2010 | 12:29 PM
martysmartie's Avatar
martysmartie
As said the warning light is telling you there is a fault somewhere, you need to the cause of the problem sort this and then the light will extinguish.
Have you tried resetting the KAM?
Martin
Old Apr 17, 2010 | 12:56 PM
RichieST's Avatar
RichieST
Disconnect the negative lead off the battery for half an hour, that will reset the light and clear any fault codes. If the light comes back on, there is still an issue somewhere!
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
