Why should this happen?
Old Apr 15, 2010 | 04:19 AM
captiva's Avatar
captiva
Default Why should this happen?
I've come to accept that my Cossie 4x4 uses a bit of oil, mostly when I use the boost, but while I was doing some work on it over a period of a week ( I had removed the heat shield from the turbo, I was too lazy to put it back on) and still driving it everyday, the oil consumption STOPPED. So put the heat shield back on and oil consumption RETURNS. Does the turbo run hotter with the shield on?
Old Apr 15, 2010 | 06:57 PM
Ridgey's Avatar
Ridgey
Doesn't make any sense that really. Couldn't see the heat shield making the exhaust or turbo any hotter in reality.
Old Apr 15, 2010 | 08:42 PM
martysmartie's Avatar
martysmartie
As said there is no reasoning to it, the turbo dosen't use oil it's the engine that burns it unless you have a worn turbo, unless it was a different driving style and did you cover the same distance? It's actually dangerous to drive without the heat shield as being so close to the flammable brake fluid which is why Ford fitted one.
Martin
Old Apr 16, 2010 | 05:17 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Martin
LHD i guess, so on the other side
Old Apr 17, 2010 | 04:55 AM
captiva's Avatar
captiva
I can't explain it either, yes it is LHD, so I have the shield off now for another week and it looks as if the oil consumption has stopped again. I did notice when the shield was on and I looked under the hood one day, the turbo was glowing cherry red hot, but this may be normal.
Old Apr 17, 2010 | 05:02 AM
MARCOSWORTH
Depends on how heavy your right foot is
Strange problem you've there
Becka674
11
Oct 8, 2015 03:11 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
