Oil light flashing on idle
Old Apr 11, 2010 | 06:41 PM
Kammer111's Avatar
Kammer111
Default Oil light flashing on idle
My oil light flashes intermitently on idle only. If I accelerate it goes off and everything is fine.
I am yet to change the oil. I have engine flush to go through it then will change oil and filter.
It's a 1.6cvh efi mk4 escort.
Is this something to worry about?
Old Apr 11, 2010 | 06:43 PM
tomoyb's Avatar
tomoyb
yes oil pressure sounds dodgy to me
could be a spun shell
Old Apr 11, 2010 | 06:44 PM
DangerousBryan's Avatar
DangerousBryan
if its been stood for a while an oil change might fix it. if not,its fooked.
Old Apr 11, 2010 | 06:45 PM
COLEYST200's Avatar
COLEYST200
have a look at the wire that gose onto the pressure swich
Old Apr 11, 2010 | 06:49 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
you would hear it if it has spun a shell
Old Apr 11, 2010 | 06:53 PM
rs-tuner's Avatar
rs-tuner
As above if the wire is ok then change the switch . If that doesent fix it it will prob be the oil pump
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
Adam-M
Aug 26, 2015 05:53 PM
