Advantages of using a coil pack instead of a Distributor?
Old Jan 12, 2005 | 05:26 PM
CliffRS4's Avatar
CliffRS4
Default Advantages of using a coil pack instead of a Distributor?
As above on a cossie managed rs turbo
Old Jan 12, 2005 | 05:32 PM
alan rainbow's Avatar
alan rainbow
you can use a biger plug gap / better idle / you do away with things that brake down ie dizzy cap/ rotory arm / dizzy
Old Jan 12, 2005 | 05:37 PM
NUTS RuS's Avatar
NUTS RuS
I did it because its 3 less things to worry about
Then retired from my 2nd rally in this car because of it
Old Jan 12, 2005 | 06:35 PM
markk's Avatar
markk
Old Jan 12, 2005 | 06:58 PM
slowpoke's Avatar
slowpoke
how much does it cost to do this on a cossie roughly ??
CliffRS4's Avatar
CliffRS4
Is it much work to change and roughly how much would it be to do this?
Old Jan 12, 2005 | 07:22 PM
NUTS RuS's Avatar
NUTS RuS
Cost me about £45 from the scrapyard for the Vauxhall coil pack.
Old Jan 12, 2005 | 07:25 PM
Graceland's Avatar
Graceland
Team HOTHOT!
do u not own a big coat
Old Jan 12, 2005 | 07:27 PM
alan rainbow
or a empty tool box
Old Jan 12, 2005 | 07:30 PM
NUTS RuS's Avatar
NUTS RuS
The coat and tool box were full of other bits
Old Jan 12, 2005 | 07:34 PM
cossie550+'s Avatar
cossie550+
vauxhall coil pack , ever wonder
Old Jan 12, 2005 | 07:40 PM
Oranoco's Avatar
Oranoco
That'll be the problem then
Old Jan 12, 2005 | 07:45 PM
NUTS RuS's Avatar
NUTS RuS
My car when built had only 1 bit of the original Rover wiring loom in it.
It was this bit of the loom that turned out to be faulty not the actual coil pack. It soon ended up in the bin and a new loom made by MEFmotorsport and has performed without a single fault since
alan rainbow
zetec ones are £38 new
Old Jan 12, 2005 | 07:49 PM
NUTS RuS's Avatar
NUTS RuS
but thats a Ford bit That would have been tooooo easy
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
20/20 vision
Sep 29, 2015 11:27 AM
