change wheel bearing
Old Apr 7, 2010 | 05:22 PM
rsturbo27's Avatar
rsturbo27
Cool change wheel bearing
how hard is it 2 change a wheel bearing front on a clio p reg do i need special tools or wot should i expect a garage to charge me cheers
Old Apr 7, 2010 | 06:14 PM
is it a front one or a rear bearing. I think you will need a press to get the old one out and the new one in.
Old Apr 7, 2010 | 06:35 PM
rsturbo27's Avatar
rsturbo27
its a front 1 m8 how much will a garage charge do u think
Old Apr 7, 2010 | 08:07 PM
bythomson's Avatar
bythomson
you could prob do it yourself i did a puma front wheel bearing and it was relativly easy you would need a bearing insert tool
http://cgi.ebay.co.uk/WHEEL-BEARING-...item2eac239205
just clean all mating surfaces with emery papaer then oil them up and gently and evenly inserrt the bearing with the above tool
or take the hub of the bar and take it to garage it should keep the cost down
Old Apr 7, 2010 | 08:09 PM
stevos's Avatar
stevos
Its a piss easy job mate you just need to take care putting the new bearing in or get a garage to press it in for you.
If you do it yoursef will probably save you 60 bucks or so
JoeyBoyden
Jan 4, 2024 02:36 PM
malkiemac3579
Jul 14, 2017 12:10 PM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
muz
Aug 1, 2015 06:48 AM
