Tapping noise
Old Apr 5, 2010 | 04:07 PM
stevehannah87's Avatar
stevehannah87
Default Tapping noise
Hi every1, i have a slight tapping noise coming from under my sierra when sat on tick over. when sat in the car it sounds like the cams, but listening to the engine the only noise is the injectors ticking. it comes from around where the down pipe and center section of the exhaust meet. does any1 have any ideas or is this normal
Old Apr 6, 2010 | 07:26 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
when was the last time ya changed ya clutch it could be the reliese bearing
Old Apr 6, 2010 | 12:47 PM
martysmartie's Avatar
martysmartie
It could be tappets? If CVH Sierra they are hydraulic I think DOHC is as well, Pinto are solids which are adjustable. Release bearing is generally more a "whirring" noise and if so it will disappear when clutch is depressed.
If defiantly under car as sounds can be tricky as appear to be from elsewhere, I would check exhaust mountings.
Martin
Old Apr 6, 2010 | 01:40 PM
gingerturbo
yeh true that my escort taps and which i know are the tappets and it sounds worse sitting in the car than when the bonnet is up and infront of it
Old Apr 8, 2010 | 05:44 PM
forevaford's Avatar
forevaford
gearbox noise??
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
marky_g
Sep 12, 2015 04:26 PM
rsturbo27
Sep 5, 2015 05:08 PM
