Workshop build. Phase two !
Old Apr 4, 2010 | 09:58 PM
markk's Avatar
markk
Default Workshop build. Phase two !
Take one average sized rear garden..................................
add in one of these....
and one of these
how much concrete do you have to put in footings then ?
the ground works are 900mm deep in most cases, and is 10m x 8m
the deal is i have a builder who is doing the job on a labour only basis, so im providing the materials, so im trying to decide on the amount on concrete I need to use firstly for the footings and secondly on the base.
any ideas?
Old Apr 4, 2010 | 10:01 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Jesus Christ, thats some serious machinery.
how big is this shed, is it only having flat roof, is there any need to go that mad with the footings?
Old Apr 4, 2010 | 10:06 PM
markk's Avatar
markk
took out 60 tons roughly in 5 hours !
10m x 8m and 4m to the ridge. dual pitched.
Old Apr 4, 2010 | 10:10 PM
Mcgarry's Avatar
Mcgarry
5.2 metres based on 9 inch thick and 2 foot wide mate
Old Apr 4, 2010 | 10:15 PM
markk's Avatar
markk
them footings are roughly 2'6" so approx 6 cubic meters then.
not so bad.
what about the base then, ive got mesh and mesh men to sit it on, to give strength, would you go for 4" or 6" or more ?
Old Apr 4, 2010 | 10:22 PM
Mcgarry's Avatar
Mcgarry
12 meters for the slab mate, id go for 6 inch in a garage
Old Apr 4, 2010 | 10:36 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
what do you reckon the total spend to be? as i will be looking in to something like this in the next year or so
Old Apr 4, 2010 | 10:40 PM
markk's Avatar
markk
im doing my very very best to get it water tight at 13k pal, anymore and im in trouble.
Old Apr 4, 2010 | 10:41 PM
Matt Baxter
Back in black!
Thanks for that gives me something to think about
Old Apr 4, 2010 | 10:42 PM
LHD220Turbo's Avatar
LHD220Turbo
is this your garage/ workshop? if so it will be a useful space once complete!
Old Apr 4, 2010 | 10:51 PM
markk's Avatar
markk
yes just at home for my own personal use.
Old Apr 4, 2010 | 10:56 PM
Matt Baxter
Back in black!
keep us updated please what sort of time scale do you think it will take
sorry for all the Q's
Old Apr 4, 2010 | 11:07 PM
nuttynil's Avatar
nuttynil
RS nutta
def 6 inch for floor base
Old Apr 4, 2010 | 11:10 PM
markk's Avatar
markk
before winter comes hopefully !
Old Apr 4, 2010 | 11:43 PM
james kiely's Avatar
james kiely
mark it would be worth using some 383 mesh in your foundations will stop any cracking ,also dont leave the foundation open for long ,get the concrete in asap
you should get 8 sheets and use two in the foundations and the other 6 in your floor
Old Apr 5, 2010 | 09:02 AM
dave cos4x4's Avatar
dave cos4x4
very nice size Mark, be great when finished.
Old Apr 5, 2010 | 09:47 AM
markk's Avatar
markk
Foundations should be filled hopefully by wednesday afternoon once building inspector has been and its ok,
and we have 11 sheets being dropped off tomorrow morning
Old Apr 5, 2010 | 09:48 AM
markk's Avatar
markk
we originally wanted it bigger but the planning dept of our council put that one to bed before we even started, so its had to be done on permitted development
Old Apr 5, 2010 | 10:23 AM
Stu @ M Developments's Avatar
PassionFords Creator
Looking good Mark.
Old Apr 5, 2010 | 10:28 AM
Lee Reynolds's Avatar
Lee Reynolds
Mark,
nice straight dig like that mate just mass fill the founds till about 150mm below F.G.L.
It will be around 16m3, which you should get around 65 quid per m2 at that amount. Thats about Ł1040. If you think about it, you will have to put at least Ł350 in concrete anyways, plus about 350-400 quids worth footing blocks, then sand cement and labour! Its not worth the hassle. We always mass fill if the situation allows it!
Old Apr 5, 2010 | 11:05 AM
AJC's Avatar
AJC
Good work.
Old Apr 5, 2010 | 11:28 AM
ian sibbert's Avatar
ian sibbert
Mark,
You got the concrete sorted yet?
Paul Murphy @ Premier Readymix NW Ltd is a mate of mine and loves his rallying lol, try him for a price...
01995 600555, 07743 815410
Old Apr 5, 2010 | 05:11 PM
markk's Avatar
markk
Originally Posted by Lee Reynolds
Mark,
I'll let the builder decide how he wants to do it, but I have 10 tons of mot arriving on Tuesday, and the concrete will be ordered wed morning hopefully.
Originally Posted by AJC
Good work.
Cheers, decided a brick built would more suit the surroundings, even though costing more in the long run.
Originally Posted by ian sibbert
Mark,
Called him, gonna sort me a price
Old Apr 5, 2010 | 05:14 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Looks a good size that
Old Apr 5, 2010 | 05:22 PM
markk's Avatar
markk
not as big as the land around it, but, the council put a stop to me using the extra 2 meters either side, and 2 behind it.
Old Apr 5, 2010 | 06:20 PM
gus's Avatar
gus
very jealous
same size as i could build here, just need to buy the place first instead of renting
Old Apr 5, 2010 | 06:37 PM
don_'s Avatar
don_
and one of these
any ideas?
i would say 7.2m3 of concrete for the footings which i would use a 1.3.6 mix or gen 2 at about 60 slump this will make it nice and easy to gat a good level and a p320 / p330 mix with fibres for the slab at 6" deep which should be about 1.2m3 again 50 / 60 slump , if you go for mesh a252 will be more than enougth [ if so use a 50/60mm spacer to keep the mesh of the floor ] but if you add fibres it will make it bullet proof and only cost about Ł5.00 more a m3 . i see you are in lancashire ? if so let me no what materials you need as i am a manager of a builders merchant in burscough with plenty of branches around and i could poss help out with any problems or materisl
cheers fella and good luck
Old Apr 5, 2010 | 07:01 PM
Shings's Avatar
Shings
Mark
I am a quantity surveyor its simple enough to do, you need to work out the centre line of the trench to give you a perimiter and then times it by width and depth of the trench to give you the conc. for the foundations.
So
How wide is the trench?
What are the measurements to the extremes of the trench?
Do you want the conc. required for the slab as well? Need the depth of the concrete as I can work the rest out from the other measurements.
Jake
Old Apr 5, 2010 | 07:37 PM
markk's Avatar
markk
Im in Preston actually, which merchants you at? i still need to buy for a roof and a house extension/double roof dormers !
Originally Posted by Shings
Mark
So
Jake
Hi Jake,
Trench is 750mm wide, to the outer extremes are 10m x 8m, the slab will be inside that at 6" deep.
the 252 will be sat off the floor by 3 inch if we use a 6" base.
Old Apr 5, 2010 | 07:55 PM
Lee Reynolds
LOL at the tag! Fuck anyone who asks for advice again then Hilarious how jealous some folk get
Old Apr 5, 2010 | 07:59 PM
Lee Reynolds
You have 10 tonnes of MOT arriving? I take it you mean 10 tonnes of DOT stone? No relevance really to the foundations? ? ? ?
Old Apr 5, 2010 | 08:07 PM
Ebonycossie4x4
you going to have a ramp in there?
How many cars is she gonna hold?
Old Apr 5, 2010 | 08:41 PM
Shings's Avatar
Shings
Right Ho
Foundations
900 deep
750 wide
33000 long (centre line)
equals
33.00x0.75x0.90 = 22.275 m3
Assuming the the 900 takes the foundations to the top of the trench and you want the slab to the same height and is 6inch or 150mm deep to the same level the slab works out as follows.
8500 long
6500 wide
150 deep
So 8.5x6.5x0.15 = 8.28 m3
Total conc. required for Found. and Slab = 30.56 m3
Your supplier should be able to work that in to tonne or whatever they supply it in and ask your builder what sort of allowance should be made for estimating terms as those figures are based on the calculations provided.
If you want I can send you a spread sheet with the workings on - pm me an email address if you're bothered.
Real rough drawing to check I have understood correctly.
Jake
Old Apr 5, 2010 | 08:58 PM
dave cos4x4
very good Jake.
Old Apr 5, 2010 | 09:02 PM
gingerxr2's Avatar
gingerxr2
if theres any trees within a few metres of the trench then the inspector may ask you to go deeper,
Old Apr 5, 2010 | 09:07 PM
Shings's Avatar
Shings
very good Jake.
Cheers Dave
The whole first semester of my degree was on foundations and the exam and coursework that followed so I'd like to think I can do this, put it this way in 18mths time 3 members of the rics should give me a little badge which say Chartered on soo.....
I work in M+E though so not much call for foundations in what I do.
BUT....
As its someone elses money I would preffer to email Mark the spread sheet with my calculations on so he can see where all the numbers come from to be sure...
Jake
Old Apr 5, 2010 | 09:20 PM
danneth's Avatar
danneth
TORQUE!
like the c00nt who once wanted us to go down 2.5m
Old Apr 5, 2010 | 09:34 PM
Kieron's Avatar
Kieron
Neat digger work there.
My garage is a similar size, 10 x 7 and I had nearer 12m3 in my footings and I don't think my trench was as wide @ 600mm (I think). Two lorry loads iirc, 6m3 in each. Maybe I have that wrong as it doesn't match what people are telling you or it was my poor uneven digger skills.
For the base I used 100mm of crushed hardcore followed by 100mm of concrete with a fall rear to front.
Old Apr 5, 2010 | 09:45 PM
Shings's Avatar
Shings
600 wide and 900 deep on those measurements would be 17.06 m3 for the foundations
Jake
Old Apr 5, 2010 | 09:53 PM
Kieron's Avatar
Kieron
Could have been 700mm deep?
Mind you I am just guessing here at something that happened a couple of years back. Mines done and I'm sure there are no gaps in it. Not worth worrying about my guesses Jake, your calculations are spot on for what the op needs.
BTW mine was up and watertight for about 12k so depending on what you can get cheap and who you know 13k is possible. That price didn't include electrics and water etc though.
