Workshop build. Phase two !
#41
Could have been 700mm deep?
Mind you I am just guessing here at something that happened a couple of years back. Mines done and I'm sure there are no gaps in it.
Not worth worrying about my guesses Jake, your calculations are spot on for what the op needs. ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
BTW mine was up and watertight for about 12k so depending on what you can get cheap and who you know 13k is possible. That price didn't include electrics and water etc though.
I know mate - I've just got my work head on now, I'm one of those rare people - I actually enjoy doing my job.
#43
spot on shings,but easy here with this
http://www.cemex.ie/ps/ps_ac_ca.html
The maths is easy, its getting the correct figures to pump into the calculator.
If you measure from the external perimeter of the trench you get too much, if you measure from the internal perimeter too little so you have to work out the 'Centre Line' of the trench.
Its not complicated on something like this but gets more complicated when you're working out the centre of the trench, the cavity, the internal block work, external block work and so on... because you need to do that as well to get accurate measurements for bricks and blocks.
GOD I AM SAD TONIGHT
#44
![Confused](https://passionford.com/forum/images/smilies/confused.gif)
Perimeter of 10+10+7+7 = 34m
34m x .600 x .225 = 4.59m3 of concrete!
#48
#49
THats cheating and the easy way LOL.....
#50
It does surprise me when people give Lee grife he is a builder after all so should have a pretty good idea what he is doing,
Looks cool Mark l am doing my garden at the moment and had great fun with the digger![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Mike
Mike
#51
At what concrete depth Jake? Because if its only 225mm deep concrete then it would have only needed 4.59m3
Surely you have calculated for a mass fill at .900 deep which would be too much mass fill! It needs to finish at least 150mm below F.G.L.
I spoke to the concrete company and estimated at 5m3 for the founds and 12m3 for the base - di you get somewhere near that ?
#52
Personally for your founds id be looking at 6m3 as like i said i always use the outer perimeter measurement. That will give you 225mm of concrete depth. If theres some left over it wont hurt to put that in too, as you wont be working to a set gauge depth with it being an independant building. More the merrier so to speak
#53
But, people with valuble knowledge like Karl Norris who used to give out free advice left this site because of issues like this! So we all miss out now
#54
Totally agree, I do paper- I dont build hence what I said further up - I've done my calcs based on what has been provided so 900 deep for foundations and slab 150 deep (6 inches) inside the foundations, but you could do foundations to 750 deep and slab 150 to the extremes of the reduced level and it would work out the same - just two different lots to order.
I've not taken an allowance for any in fill at the bottom of the trench.
Re you're comment about Karl - the prob with Karl was always people challengine his knowledge and advice, if someone had come along and said I do x because of x then x but Karls method will also work then he would prob still be around.
Unft Karl was a target - I never saw any bonefide tuning businesses argueing with him.
Jake
#56
First one assuming same pour
Second one assuming two pours so found to 750 deep and slab over the whole 10x8 area.
(Both obv same amount in total but two different orders)
Third one taking your advice of using the external perm. but I coloured one of the cells and advised how to adjust it in case I'd misunderstood where the 900 went to and also for any hardcore/sand at the bottom of the trench.
I assumed 900 was to the top of the existing ground level rather than the reduced level of the slab base.
Jake
#57
thanks for all the help, and Jake for the calcs, makes sence ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
I think this is the plan (though im only summising as th ebuilds not here till tomorrow !)
MOT in to a certain level, wackered, then concrete in (maybe 250mm?) then foundation block and build up to DPC
sounds like what i would do anyway
#59
That would be about right.
Either foundation blocks or Engineering bricks (obv more expensive to lay bricks as more of them per m2, but look nicer?) to the equivilent of 2-3 courses above finished ground level externally then DPC on top. At least thats the theory - for a garage I would question whether you'd need a DPC as engineers should suffice - again in theory.
Glad the calcs etc made sense, whatever depth is left after the MOT goes in and is wackered is the adjustment in the yellow box on the sheet ( I.E from the top of compacted MOT to where you want the foundation level to be)
If you only use 250mm deep of concrete for the foundations that obviously reduces the amount you need, without checking probably to somewhere near what Lee said earlier in the thread.
#60
No way does stone go in the foundations prior to concrete Mark. Ive never come across someone doing that before!
Concrete in the strip foundations at 225 deep. Then build off the concrete with footing blocks to 150mm below FGL. Then lay 2 course of facing bricks up to FGL/slab level. Fill in the foundations with stone, prepare the slab with 200m of rolled stone to 170mm below FFL, 20mm sand blinding, layer of visqueen and then concrete!
I know different areas do things different but to put stone into a strip foundations then concrete over is madness imo!
#61
Incidently...
with a foundation of 225 (rounded to 230) deep thats 5.69m3 at my centre line
with a foundation of 225 (rounded to 230) deep with Lees suggestion of external perimeter its 6.21m3
I did think it was a lot of foundation at 900mm deep...
Lee your design sounds about right - but then you'd know that being a builder lol.
#62
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Incidently...
![](https://passionford.com/forum/images/smilies/roi.gif)
#63
Out of interest Mark how did you find the builder? Do you know him or has he come recomended etc? Is he busy? Whats the trade like around your way now?
#64
the first hurdle they crossed was the 'ok i'll be there tomorrow at 6.00pm' they actually turned up for a start.
The trade round here - i couldnt say, as i have contacted some 12 plus builders, half of them turned up, a 1/4 of them turned up on time, the rest didnt bother.
Out of the ones that turned up, they all took over three weeks to get me a rough quote (apart from the lads im using-they did it in a few days)
After asking a timescale for the quote, the scale ranged from a couple of days to 'by the end of the week' im still waiting for some of them some 8 weeks later,
Im pretty good when it comes to pricing jobs, im pretty clued up in most trades to have an idea of rough pricing, some of the quotes (2 of them) where double what its costing to do
![](https://passionford.com/forum/images/smilies/shocked.gif)
Of the ones i have spoken to and came to look at the job, all of them said they wanted the work as the job was and i quote " the quietest its been for 15 years"
yet the guy who said that, im still waiting for his ' couple of days quote' some 4 weeks later
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
So, you would have to draw your own conclusions, i think if you work hard, to make a wage in a recession, then you will survive, I think if you quote high or lazy then you will never be in work for any length of time,
The two guys (plus labourers they have) have just finished an extension, and have one waiting to do after mine, (mine is a two part job - garage then house) so I think they will go and do the next one then come back to me.
Sound busy enough if you ask me.
#65
Thats shocking tbh with the quoting especially like you say it being a quiet period! Youd think they would have had the quote there within a week!
Do they do the full service or are they a pair of brickies?
#66
They will do the lot, they have organized and sorted the dig, all im doing really is supplying the materials, they do the rest, I have alot of friends in other parts and people who I have used for years who I always give my work to, just never had any brick/blockwork done for years so had to find a new contact.
#67
Well good luck with it, hate to hear horror stories in the trade so hope all goes well ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
We recently lost an extension that were were highly recommended for, i can only assume we were massivley undercut. Good god, you should see the state of it
#69
I cannot understand the variation in prices in the building trade, and we are talking all aspects of the building trade. How one person can double anothers price for the same job i do not know a differance of near Ł14,000, how much of a differant job can you do for an extra Ł14k?
i can understand maybe a couple of K, but not 10's of thousands.
one guy quoted me over Ł10k to put a roof on this build
#70
#71
We're getting under cut all the time at the mo and we're quite cheap for what we do and have a very good reputation. When we do win a job the contract terms are really difficult to work under and loads of risk so our margins are close to 2% profit and generally we just break even - we have no idea how people undercut us as we all buy the same stuff and pay the same rates for people.
Not nice out there at the mo.
With private building I am sure theres a certain element of chancing your arm and praying on the potentially unwary.
J
#72
when he arrived at the property the owner looked a bit sheepish; it soon dawned on him that he had been to the property before. It turned out my bro in law had priced for the extension but was undercut, the company who done it has now gone bust and left this bloke with a very bad extension and a leaking roof......
sorry, slightly off topic!
#73
im a QS for a drylining and ceiling firm, and the prices that we are having to put in to be competitive for tenders is ridiculous. fixers rates, materials rates have all been slashed, and we are down to a very low profit percentage, and we are factoring in all material rebates into prices. We are not at the stage of pricing at cost yet, but i can see that coming soon.
i work in construction and still cant believe the attitude that some private builders have. Im renovating my house at the moment, and the amount of people that try it on with prices and time scales etc is rediculous, hence why I am doing the majority of the work myself, and only using people i use at work for materials. when i did my driveway, i got 5 quotes, 4 of them took 2 weeks to come, and the one who supplied me it the day after i asked for it, was Ł2k dearer than anyone else. But if i was going to get someone to do the work i would have gone for him, because it is true, you get what you pay for.
#74
my brother in law has been a builder for some 15+ years; he recently got a phone call to go and price for a leaking roof on an extension
#76
PICS OR STFU
Jake
( works when ever someones on about some fit bird or a fast car )
#79
Awesome pics, interesting to see the progress. Threads like this should be more common with forum users helping one another out. In 6 years on here, I don't think I have seen this many offers of assistance in one thread, good work.
LOL @ the tags for Lee although the title does say Builders and that is what Lee is as far as I know
