How to test front diff?
Old Apr 4, 2010 | 01:41 PM
midnight_man's Avatar
midnight_man
Default How to test front diff?
hello, is any method how to test front diff with visco? if it is working propertly. thanks
Old Apr 4, 2010 | 04:30 PM
markk's Avatar
markk
Hi, the std cosworth front diff is an open diff, not viscous.
Old Apr 4, 2010 | 04:50 PM
ECOS95's Avatar
ECOS95
Only the rear is an LSD.
Old Apr 4, 2010 | 04:58 PM
midnight_man
not a 33/66? front/rear... I read it somewhere
Old Apr 4, 2010 | 06:38 PM
markk's Avatar
markk
So you want to test the centre VC then ?
Old Apr 4, 2010 | 06:40 PM
midnight_man
yes yes..
Old Apr 4, 2010 | 07:49 PM
jammerrs's Avatar
jammerrs
video your self doing a big donut, and if all 4 wheels spin its working, if only 2 do then no
i cant think how youd be able to test it really, unless you can jack it up andstop some wheels from turning and see if the others do, really not sure
Old Apr 4, 2010 | 08:03 PM
midnight_man
yes but there is visco, no? If I good know it can move 70% power from front to rear....I listen that I can use torque wrench on rear wheel (center screw) set it on 70Nm and test the power of visco ....
Old Apr 4, 2010 | 08:52 PM
markk's Avatar
markk
you would have to do that on the front wheel not the rear, the torque distribution has nothing to do with the viscous coupling though.
Old Apr 4, 2010 | 09:00 PM
jammerrs's Avatar
jammerrs
would the torque front to rear not change as the grip changed?
Old Apr 4, 2010 | 09:08 PM
markk's Avatar
markk
nope, the split is always 64/36 iirc, the viscous only allows slip between the two driven axles.
Chas
Sep 21, 2015 08:57 PM
3drRich
Sep 13, 2015 07:32 PM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
