help terrible handling
Old Apr 2, 2010 | 01:10 PM
DAN400's Avatar
DAN400
Default help terrible handling
my car is driving like shit! its 2wd, i poly bushed the rear beam and arms last year and it has nt been the same since,but it was useable, but its alot worst now,the front is all poly bushed too,new tca s, 4 new tyres, hankooks on the rear and toyos on the front,poly diff mount,everything is like new, no movement on any suspension parts anywhere when i ve had it on the lift also had the steering lined. it seems fine through the gears but once it starts picking up a bit of speed 100mph or that it starts wondering all over the road, its got koni s all round , not sure on the springs, startin to really piss me off, no confidence at all when driving it! rear legs are fine to , no rot! what should i try next cause im baffled
Old Apr 2, 2010 | 02:14 PM
opposite lock's Avatar
opposite lock
Im gonna change the rear springs on mine apparently the koni ones aren,t great maybe its them? presuming urs are koni,s . Think its the avo team dynamics 'std height' that are recommended not 100% sure tho , and also they are still lower than std ride height. Sounds as if you,ve covered most things , im sure someone on here can shed more light on this
chassis not Team woops
Old Apr 2, 2010 | 02:45 PM
fatmike's Avatar
fatmike
get ya rear trak checked sum times the rear can be out witch can caus a crabing efect ?
Old Apr 2, 2010 | 04:50 PM
The major "floaty" feeling from the rear at speed can be caused by weak springs, and the soft rear ARB.
Opposite lock went in my car, and I'm sure will tell you it was 100% stable even well over 100, on a private road, this stability cam about due to the 22mm rear arb, I used the car for 1 month each with 16mm arb, then 18mm arb, then 22mm adjustable arb on mid setting, at which it is the same as a escos one, the high speed stability was awsome, long sweeping bends on private roads at 150 no problem, 10,000% more stable, not found a downside yet despite what everyone told me, I do have coilys and run 200lb on the rear.
Old Apr 2, 2010 | 04:59 PM
Turbosimpsons's Avatar
Turbosimpsons
did you poly bush the rear arms. this could be your problem.
Old Apr 2, 2010 | 05:35 PM
DAN400's Avatar
DAN400
yes but over a year ago maybe even 2 years ago now,and the car has done nothing in that time,this wondering has started in the past month or so , everything under the car is still as new
Old Apr 2, 2010 | 05:38 PM
WongRS's Avatar
WongRS
sounds a tad like mine, its pulls like a fucker to the left since its been polybushed!
Mine handles nice though.
Fatmike, as far as i know the rear track isn;t adjustable as standard?
Old Apr 2, 2010 | 05:43 PM
DAN400's Avatar
DAN400
my car was never the same after i polyed the rear tbh,used to sit at serious speeds thinking the car was on rails before this, but it was never as bad as it is now, maybe try a new set of springs!
Old Apr 2, 2010 | 05:45 PM
andy130's Avatar
andy130
not having much luck with it with it lately dan? hows things with you?
paul16v's Avatar
paul16v
Monte 087
As said poly bushing the rear arms could be the problem as std they are fitted with a sort of spherical bearing not a bush, also what make of bushes did you fit to the beam? my mate fitted some of those orange ones to the beam and rear arms and it made the car feel terrible, noticeably worse than the knackered std bushes he took out.
DAN400's Avatar
DAN400
so do you s all think my problem is coming from the rear? forgot to mention the car a gripper diff too!
Old Apr 2, 2010 | 05:49 PM
DAN400's Avatar
DAN400
no luck at all, see through it if the car got lots of driving,but i d say if i did 1000mile last year that would be it,and treated better than wean
Old Apr 2, 2010 | 05:51 PM
DAN400's Avatar
DAN400
yeah its them orange ones, flo-flex is nt it, but my mate put in the same as me and his is fine
Old Apr 2, 2010 | 05:54 PM
DAN400's Avatar
DAN400
if i thought the bushes that ggr sells would fix it id splash out on them,think they are Ł80 a timeso thats Ł320!!!!
Old Apr 2, 2010 | 06:57 PM
Paul_RS's Avatar
Paul_RS
Its more than likely the rear arm bushes. The standard ones are far better than any polybush on the market. IIRC you can get either the inner or the outers from Ford, but only one type, the other is discontinued....
Old Apr 2, 2010 | 07:04 PM
fatmike's Avatar
fatmike
if one of the trailing armes or hubs is slightly bent it could throw the rear track out thats what i ment lol
Old Apr 2, 2010 | 07:50 PM
opposite lock
just going off subject my pal had a saph just like yours a few years ago, gripper diff. Had a lovely full respray ? Hope you solve your ride issue
Mike
Old Apr 2, 2010 | 08:17 PM
opposite lock
Yep your car felt so in control although a little hard imo for me . Makes mine feel like jelly , we couldn,t believe the speedo tbh lol!
DAN400's Avatar
DAN400
Mike
my car came from wales mate and i got the diff off a lad on here, cheers bud
Old Apr 2, 2010 | 08:25 PM
DAN400's Avatar
DAN400
but why has it got bad all of a sudden?the rear arms havnt any movement ! i m just in from the garage and the only thing i came across is one off the rear koni s is alot softer than the other,its not leaking but is def softer! could this be my problem? thanks for all your replys lads
Old Apr 2, 2010 | 08:33 PM
martysmartie's Avatar
martysmartie
You could try readjusting both back shocks evenly, despite not having been touched, may have got altered somehow and it's free!
Martin
Old Apr 2, 2010 | 08:36 PM
james kiely's Avatar
james kiely
have you done the steering bush dan?
Old Apr 2, 2010 | 08:40 PM
DAN400's Avatar
DAN400
the steering column one?? no james!will have a look at that tomorrow,my heads fryed
Old Apr 2, 2010 | 08:42 PM
DAN400's Avatar
DAN400
Martin
i think one is fucked mate, making like a squelching noise!
Old Apr 2, 2010 | 09:28 PM
cossiegreg1's Avatar
cossiegreg1
rear bushes are meant to be spherical/ solid, poybushing them is your problem
Old Apr 2, 2010 | 09:30 PM
cossiegreg1
also a fooked shock wont help, but defo your bushes at fault imo
Old Apr 2, 2010 | 09:40 PM
155lee's Avatar
155lee
cheap poly bushes?they wear \quick and are cheap cos they arent that good,i poly bushed my whole 2wd saph with powerflex bushes and it was on rails.my old rack had play on 1 side,no knocking or anything,this caused wandering and twitchyness when hitting cats eyes,check that.possibly the uprated bushes have shown up a weakness elsewhere.
Old Apr 3, 2010 | 08:53 AM
Papillon's Avatar
Papillon
had the same problem, car was all over the road giving no confidence and braking was quite scary. was one of the steering rack bushes i think its called. poly´d it and was fine
later had a new set of toyo t1-r fitted on the back and i was back again, no responce from the rear making highspeed lane shifting very unstable. have always used the toyo´s but something must av been wrong with this set, went back to originals and traction was fine again.
Old Apr 3, 2010 | 12:46 PM
Mike1's Avatar
Mike1
Quite a lot of people complained about poor stability after fitting Toyo T1R tyres going back some years. IIRC Stu ( MSD ) was one of the people who noticed this on their own Cosworth. Sidewall flex or similar
I'm not sure if they improved them after but I do know some people who still aren't impressed by them and have gone for Flaken FK452 as a similar priced replacement
Old Apr 3, 2010 | 02:18 PM
Papillon's Avatar
Papillon
Ive always had them but this time there was a significant change, maybe because i didnt have it streched had 215 on 8" rim, now went up to 225, it was a nightmare. Was looking for some falkens but got hold of some eagle f1 even cheaper
Old Apr 3, 2010 | 03:34 PM
Harris.'s Avatar
Harris.
I had the same problem when i fitted new bushes on my xr2 , felt so unsafe etc .
Your problem is them rear bushes , you have also fitted the cheaper ones which imo i would never fit to my 3 door . they warp and split after a short period of time . as people have said above the rear arms are fitted with a bearing bush .
Change them asap along with your shock. or look to see whos breaking a cossie and just get the arms complete .
Old Apr 4, 2010 | 02:52 PM
Turbosimpsons
only inner one's available at ford, iv'e just had some.
Old Apr 4, 2010 | 02:55 PM
Turbosimpsons
iv'e got some nearly new lowered rear springs and 1 good koni shock Ł50 + postage if your interested.
Old Apr 10, 2010 | 07:39 PM
DANROM's Avatar
DANROM
Graham goode has the inner and outer bushes for rear arms.
ggr1093 and ggr1092.
Old Apr 10, 2010 | 07:50 PM
james kiely
any update dan?
Old Apr 10, 2010 | 07:58 PM
DAN400's Avatar
DAN400
well when i actually got round to checking the car over again i found the shaft was nt out at all,so i put the t1r s on thr rear and hankook v 12 s on the front,believe it or not that sorted my problem,strange how some tyres just dont agree with some cars!
Old Apr 10, 2010 | 08:28 PM
james kiely
result dan,i never thought tyres ,especially good makes would make that kind of a difference mate .
are you feeling the love again now dan lol?
Old Apr 10, 2010 | 08:47 PM
DAN400's Avatar
DAN400
oh yes all happy again lol, out for a blast this evening and it def brings a smile back, only thing is the super unleaded is Ł1.40 not so good
Old Apr 10, 2010 | 08:51 PM
james kiely
yes dan petrol is sneaking up all the time recentley,i put 40 euros in the other day and it only went over quater full
wowk
Mar 30, 2021 07:49 PM
Jun 26, 2017 06:18 PM
turbotrev
14
Sep 27, 2015 10:44 AM
focuspower
Sep 19, 2015 08:27 PM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
