Boost drop after new intercooler!
Hello all!
Tonight i fitted (i meaning a mate) a new bigger intercooler and since then i just gave ait some (couldnt help meself) and ive lost 5lb of boost!
Any ideas...all hoses,clips,brackets were done up tight! so im sure theres no leak there!
could it be cus of the larger size and more free flowing nature?!
Thanks for any USEFULL input (yes AJ thats aimed at you!
Regards
James!
) Regards
James!
Yeah if u get a bigger intercooler i though its quite norm to get a bit of a boost drop, though not sure what the average drop is though sorry. Nrom fixed by winding the actuator a bit more
i only lost about a lb of boost when i fitted mine and that was a big increase in capacity! is everything exactly how it was before?
why not just adjust the bleed valve to get back to full boost??!
Originally Posted by Ryan
depending on the core and the style you will get a boost drop
5psi is quite alot though
Thats what i wanted to hear! ive gone from a half size pace to a large core rad tec! so it wouldnt surprise me to get a big drop! just means me stg 3 turbo goin to be doin its worth come friday when she gets set up!
rick just wondering if the cooler causes a 5psi boost drop would that mean the turbo is technically gonna be over speeding
, as in a loose boost pipe makes a turbo over speed ect
jsut wondering, could be wrong obviously ( not like it would be the first time
At the moment, the turboi will be doing exactly the same as it was. There is still the original boost in the compressor housing, which is where the actuator is taken from. If the actuator was being fed from after the intercooler, what would happen is that the engine would see the same pressure as it did before, but the compressor pressure would be up 5psi, and the turbo working harder.
You are in effect having to generate 5psi of boost just to get the air through the intercooler - thats a lot of power to waste.
If you had gone from Standard to the Radtec, I would have said could be Pressure Drop across the Cooler, however, you went from Pace to Radtec. I reckon 5psi is too much.
Check all your connections again. You would be surprised how tight those Jubilee's have to be.
I think 5 psi is too much.
But....
No, as the Pace flows very well, it's got a greater cross sectional area than the std, and the same flow path.
But....
you really should be experiencing a pressure gain from fitting a correctly specc'd intercooler.
Pressure loss equals power loss
normally- winding the boost back up to where it was, generates more heat
Originally Posted by Oranoco
When I went from my dinky Pace to the big Pace I noticed very very little drop in pressure.
I would say you have a problem somewhere, re check all the hoses and clips mate
and ya would bever notice the ammoutn of boost ya stick through your car steve either
Originally Posted by Rick
Sounds like it could be a shit intercooler. This is why ACT's mean jack shit on there own.
Thats actually a very good point... people do seem to get carried away with ACT's and not even consider Internal air flow, external air flow, volume etc... All equally important factors when designing a high performance cooling system
well for once looks like my problem has started a good debate!
Will go out today and check all me hose's!
Got a feeling its the one from the bottom of the turbo to the intercooler!
Thanks for all the help guys!
rst steve, how did you mount your fan?!
Originally Posted by Pro Alloy Motorsport
Did you get it sorted James??
getting set up friday! will see if christian spots something i didnt! (more than likely)
i fully checked it all! and it all looks totally sound! and i made sure it never got knocked or anything!
It took pride of place on the mantal! lol...
So far as everything looks and feels its all complety sound!!
i really appreciate all the help guys honestly!
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
