Inlet manifold check ??could it cause no spark
Old Mar 31, 2010 | 12:57 PM
searlesy's Avatar
searlesy
Question Inlet manifold check ??could it cause no spark
s1 rs turbo
I'm in need of some help please need it check where the plugs to the sensors go ihave a big dark brown sensor ,little light brown sensor,black sensor for air and white for fuelthen i have a blue connector,dark brown connector black connector and a white connector,if they are wrong could it cause it not to spark anybody got any ideas ie black to black dark brown to blue !?Thanks chris
Old Mar 31, 2010 | 04:28 PM
boost mad's Avatar
boost mad
What car ?
Old Mar 31, 2010 | 06:30 PM
searlesy's Avatar
searlesy
rs turbo s1
Old Apr 2, 2010 | 10:54 AM
martysmartie's Avatar
martysmartie
The ignition on these is inducive discharge system (I.E) it has a module in the dizzy this information is then passed to the ESC module I believe, this then calculates the spark advance this is what switches the coil. Check the green wire as this is known to break. There is a vaccum hose which goes to the module from the inlet manifold so check this along with module as well.
Martin
jessie_rs
62
Aug 6, 2019 09:27 PM
DixieTheKid
Sep 14, 2015 09:04 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
Si B
Sep 12, 2015 06:49 AM
