killed ka
Old Mar 30, 2010 | 04:58 PM
coolblue's Avatar
coolblue
Default killed ka
after a great day out to lyddenhill sunday i got home and found my daughter had binned her ka which left her o/s front wheeltucked under due to a bent wishbone.ive stripped it down and shes done the leg also.it looks like i can change all these but where thedriveshaft was pushed back its dented the front mount for the wishbone support bracket.the bracket is ok but looks like it would be a pain to remove the bolt at anytime.can anyone tell me if this would be a problem at the next mot thanks
Old Mar 31, 2010 | 01:26 PM
steve4i's Avatar
steve4i
is it the subframe that's damaged>? aslong as it's not severly reduced in strenght or damaged severly then it will just be a pass and advise but it depends on the tester at the end of the day
Old Mar 31, 2010 | 05:51 PM
coolblue's Avatar
coolblue
cheers bud,it is a support leg off the subframe which is a box section one side whitch is ok and the side you can see with the wheel off has two lips. the driveshaft side has been pushed back.everything seems to measure up ok so it may fail on weakness.praps try to pull out abit and mayby a small plate to cover ?cheers for answering
JK12
33
Apr 26, 2021 12:09 PM
Rsmat
63
Sep 25, 2015 12:11 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
