Inlet manifolds for Zetec turbos, why frst?
Old Jan 11, 2005 | 01:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Inlet manifolds for Zetec turbos, why frst?
just been thinking, why is it most commenly the frst inlet that is used on a ZT??
whats wrong with the alloy one, and the later plastic style ones???
is it simply cos the zetec injectors are poo, and with the frst inlet you can use different injectors?
Old Jan 11, 2005 | 01:33 PM
Oranoco's Avatar
Oranoco
I rememebr somebody saying the RS1800 inlet manifold was the best Ford one to use. Can't remember who it was though.
Old Jan 11, 2005 | 01:40 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Originally Posted by PhilM
Why people use FRST inlet manifolds on Zetecs I dont know, check the nicely matching port shapes
This is why we use the Rover manifold
Hope this helps some of you lot as I know theres a few of you doing the same thing, or plan to do the same thing...will update soon when I get my block back (onday, maybe, never ....the quality is worth waiting for! )
Old Jan 11, 2005 | 01:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers adam, but finding a rover inlet is a mission in itself...
oranoco, the rs1800 inlet it the alloy over the top jobby as found on all early zetecs.
but decent ie end fed injectors dont fit directly.
although for my throttle body conversion i have made a custom fuel rail to use cossie injectors on a zetec inlet
Old Jan 11, 2005 | 02:03 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Adam, top quote mate
Dan, I dont like using FRST ones (see above ), I dont do the adapter plates for them, but Lewis said the oens he has looked like they'd been engineered with a spoon
PM Red16, he has a Rover manifold for sale
Old Jan 11, 2005 | 02:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, basically i had the idea of doing a cheap as poss ZT not worried if it goes bang either, just to see really if it will work!!
instead of using a decomp plate i would get the pistons skimmed 1mm, yes i know everyone says it wont be reliable/shit
but how many peeps have actually tried it??
not many i bet!!
is 1mm enough tho?
cant remeber if its 1mm for zvh and 2mm for zt??
anyway, i can prolly get all the machine work done just want to know why the alloy zetec inlet is not used?
Old Jan 11, 2005 | 02:25 PM
PhilM's Avatar
PhilM
Mainly due to the fuel rail mate .
Be a good little project that bud.....I used 1mm machined pistons (7.8:1) in my old ZVH. I'd rather have machind pistons anyday over a spacer plate, at least you have propper sealing between head and block then!.
If you need any help mate, jus shout PS. is it a 1.8 or 2ltr?
Old Jan 11, 2005 | 02:29 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah, will skim them not use decomp plate
prolly do a 1.8 mate as they are easy to get and piss cheap.
no doubt ill catch you on msn mate at some point.
also the fuel rail i made to use cossie injectors on mine for the tb's wasnt hard....
Old Jan 11, 2005 | 02:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
oh, do you know what cr i will get from a 1.8 zetec with 1mm skimmed pistons??
cheers bud
Old Jan 11, 2005 | 02:33 PM
PhilM's Avatar
PhilM
1mm = 9.2:1
2mm = 8.5:1
Calculated. Measured may vary
Old Jan 11, 2005 | 02:45 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers mate, although, you cant take 2mm off a piston can you??
and is 9.2:1 too high?
only aiming for 200 - 220ish bhp?
Old Jan 11, 2005 | 02:47 PM
PhilM's Avatar
PhilM
Find a set of Calibra turbo pistons mate 7.4:1 and very cheap if you can find um!
Old Jan 11, 2005 | 02:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
that means 2.1 tho dont it??
i just want to see what a stock engine is capable of with skimmed pistons.
fed up of peeps who have not done it saying it wont last 5 mins, fair enough, if it does go bang i would have prooved it.
and as i said, im not worried if it does.
just as an experiment
Old Jan 11, 2005 | 02:51 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
unless i use a CVH head and skim 1mm hmmmmmm
Old Jan 12, 2005 | 07:43 PM
tonyturbo's Avatar
tonyturbo
i'v got 1mm skimmed standard pistons in a 1.8 16v zt. i use the zetec alloy inlet with a frst fuel rail. not done any miles yet. like you i am only looking for 200 -220bhp.
Old Jan 12, 2005 | 07:49 PM
CozzyBrom's Avatar
CozzyBrom
i dont no what a rover one looks like inside but a zoo plenum with 45mm ram pipes with bolt on to zetec throttlebody inlet with ease
Old Jan 12, 2005 | 08:00 PM
M Brian's Avatar
M Brian
not quite sure of the thinking here....
skimming pistons... they potentially take the lot out...
decomp plate or copper gasket perhaps... it fails..... erm??... shouldn't do owt.
what richm and tony pastie did seemed to be effective for 200+bhp and relatively cheaply.
how hard is it to put the FRST fuel rail onto the zetec?? as ive got a 1.8 zetec doing fook all at the mo and a more than enough spare FRST bits and pieces!! hmm
Old Jan 12, 2005 | 08:02 PM
M Brian's Avatar
M Brian
and how much???! any pics?
Old Jan 12, 2005 | 08:23 PM
mrviper's Avatar
mrviper
use a caveleer 1.8 8v fuel rail and the zetec fuel rail and stick cosie injectors inbetween
il take a picture of one i did earlyer
it works because i used them on my 2.0 n/a fiesta with a fse fuel regulator
Old Jan 12, 2005 | 08:34 PM
mrviper's Avatar
mrviper
took me about an hour to do and cost a fiver
Old Jan 12, 2005 | 08:41 PM
tonyturbo's Avatar
tonyturbo
its not difficult. remove zetec injector rail and injectors etc. u have to machine out the holes where the injectors go as the frst fuel rail puts injectors in at a slight angle. u then have to weld a couple o brackets on to inlet to fix rail onto.
Old Jan 12, 2005 | 08:46 PM
CozzyBrom's Avatar
CozzyBrom
i have done one already i will get customer to email the pics
its a throttlebody inlet with a zoo style rst plenum cover with 45mm rampipes inturnally and a cozzy thottlebody at the end
all polished
and bling
Old Jan 12, 2005 | 09:16 PM
nthorpey's Avatar
nthorpey
anything like this brom ?
Old Jan 12, 2005 | 09:41 PM
CozzyBrom's Avatar
CozzyBrom
yes that sort of thing
Old Jan 12, 2005 | 09:47 PM
richm's Avatar
richm
Dan, IMO you are going to need to find 2mm minimum - have a look at how thick the standard CAST piston is and then see if you really fancy taking that much off..
Fair play to you for wanting to actually try stuff to find out what it ACTUALLY does though
What are peoples EXPERIENCES of decompression plate failure? seriously, I'm interested in real experience, not pub talk..
mrviper - nice work with the Cav rail!!
Old Jan 12, 2005 | 10:02 PM
mrviper's Avatar
mrviper
there fine with a 1.8 but 2 litre are wider so break a bit easyer i have been told your ok for 200bhp if you get the car properly setup so its not runing lean/geting too hot
also been told no problem with 10psi
i bought a decompression plate but went for pistons so i could run shed loads of boost and rag it around a track
so if you want a 2.0 decomp plate drop me a pm
Old Jan 12, 2005 | 10:10 PM
mrviper's Avatar
mrviper
whats that small pipe going in to the crossover pipe where the temp sensor used to be
just trying to find out what the best breather setup is for a ZT
Old Jan 13, 2005 | 07:20 AM
rich_frst's Avatar
rich_frst
any know or used a frst throttle body on a zetec inlet manifold?!?!
Old Jan 13, 2005 | 09:32 AM
richm's Avatar
richm
feed out to the Idle Air control valve.. nothing to do with breathers..
Old Jan 14, 2005 | 07:55 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers guys, i have have decided to go de comp plate route as if it does blow the gasket its far easier to replace, unless the whole thing goes bang lol.
ive got an astra 1.8 sri in my garden so ill rip the fuel rail off that and have a look.
here is the fuel rail i modded for my TB's
for that im using saph cos dark blues
Old Jan 14, 2005 | 04:33 PM
mrviper's Avatar
mrviper
how did you paint that rocker cover ? looks brill
Old Jan 14, 2005 | 04:43 PM
mrviper's Avatar
mrviper
yup! got one here with the adapter plate fited to it so i could use my cvh management with a 2.0 zetec engine
Old Jan 14, 2005 | 04:53 PM
mrviper's Avatar
mrviper
i removed it because i installed omex on my car and had a 2.0 tb laying around from when i got the lump from the scrap yard
oh yeah and there is naff all diference in the size of the throttle between 1.6 cvh and 2.0 zetec
Old Jan 14, 2005 | 05:15 PM
rich_frst's Avatar
rich_frst
wicked, just what i wanted to hear...
tried saving your pic's mate, but it won't come up when i open it, have to use another program to open it.. but still no luck
Old Jan 14, 2005 | 07:10 PM
M Brian's Avatar
M Brian
rigth click save file and make sure that it has the .jpg extension at the end.
Old Jan 16, 2005 | 01:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i ripped the fuel rail off the astra pile in the gardn yesterday, looks the same as yours mate, bit of gringin here and there lol and its about done
not pics tho as the missus has left the camera at her school....
did you weld on that bracket to hold it to the zetec bit?
all i gotta do it sort out the brackets and thats it.
Old Jan 18, 2005 | 04:37 PM
mrviper's Avatar
mrviper
yep weld a bit on mate and clip the injectord on with the clips and bobs ya uncle!!
i can post the throttle body to you to copy id you like then post it back to make life easyer !
sorry about the delay in posting!
Old Jan 18, 2005 | 08:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no worrys mate
do you need to use the FRST TB then??
is the throttle pot different to zetec?
Old Jan 18, 2005 | 09:25 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
IMO the FRST inlet works perfect!
I have seen the VERY BAD conversion plates for the zetec which made me make my own for this car.
Once you have a FRST/EFi inlet most other componets are industry standard fittment (ish)
Old Jan 18, 2005 | 09:31 PM
tonypastie's Avatar
tonypastie
PhilM
hey we never had a problem sealing it up mate depends what you use and nobody to this day has worked it out yet heres a clue it comes from the states
