The next big thing for cossies/YB engine ?
Old Mar 23, 2010 | 04:24 PM
ECU Monitor Enthusiast
Question The next big thing for cossies/YB engine ?
Well we have had for the trusty old YB so far .......
8 injectors
Air Injectors
ECU monitors (PC and Standalone)
Closed Loop Fuelling on OEM Ecu
Coil Pack conversions on OEM ecu
ALS conversions on OEM ecu
Launch Control conversions on OEM ecu
Sweeeeeeeeeeeeedish inlet manifolds.
Inlet Manifold spacers.
Magnetic drain plugs.
Whats the next big thing ? .....
I am just curious if people have new "wish list" ideas on electrical or mechanical items or new trends that could be applied to the YB ?
The only thing I can think of roght now is closed loop wideband on the OEM ecu.
Sensible discussions welcomed
** OEM= Original equipment manufacturer
** This isnt an advert for me or MSD ... LOL
Old Mar 23, 2010 | 04:26 PM
R4N SS's Avatar
R4N SS
an S8 ECU
Old Mar 23, 2010 | 04:29 PM
R4N SS's Avatar
R4N SS
in all seriousness i think its good the OEM ECU is being developed further.
However, to me it just seems crazy money to have all these newer features added to an old ECU which then makes it more expensive than equivalent modern ECUs (and with most modern ECUS you get a new loom too so more saving).
Old Mar 23, 2010 | 04:37 PM
JamesH's Avatar
JamesH
Completely agree with Ran, only reason I went with all the L8 MSD gear is cos I got it cheap, having said that, it is still quite good
Simon,
Could it be the coil on plug conversion you're developing
I'd really like a SECS monitor that works with REVS on the coil pack conversion
It could be a really interesting thread, and over time it will be good to see what is next...maybe more people putting bigger turbos on standard heads?
Old Mar 23, 2010 | 04:40 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Id be interested to see a variable cam timing arrangement tried given how cam timing sensitive the YB seems to be, so I reckon it could work well.
But TBH I just cant really see the point in trying to turn the YB into a modern engine, either enjoy its brutal 80s simplicity or buy a more modern engine I reckon!
Old Mar 23, 2010 | 04:42 PM
R4N SS's Avatar
R4N SS
i think Rich has done the put big turbo on std engine and got good results
for me it all depends upon how much more power you can extract from the engine over a std ecu and its driveability.
Most of the add ons that have been developed are std equipment on modern ECUs so why would you pay to have this added onto an old ECU?
I dont have a cossie anymore but i found all the options I wanted on mine were only available as add ons to the existing OEM ECU and thus were very expensive when compared to installing a modern ECU with new loom and map.
cozmeister's Avatar
cozmeister
More boost Igor!
Simon,
Coil-on-plug is pants. So I'm told...
Old Mar 23, 2010 | 04:59 PM
james kiely's Avatar
james kiely
diy ,cheap knock sensor
Old Mar 23, 2010 | 05:05 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
why would coil on plug be pants?
is it not a stronger individual spark to each cylinder.
Old Mar 23, 2010 | 05:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Fuck me thats twice i've agreed with you this week chipper.
Old Mar 23, 2010 | 05:17 PM
PAUL S's Avatar
PAUL S
Getting its lardy arse weight down.
There are a couple of manufacturers of alloy blocks now for the YB but not heard much about how well they perform, especially at higher bhp levels.
Old Mar 23, 2010 | 05:22 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
How about a cheaper Accuvolt system than the Jacobs to run at 15v for Fuel Pump & will also supply 12v to all other accesories even when the Alternator fails & the battery drops to under 8V.
Old Mar 23, 2010 | 05:35 PM
jammerrs's Avatar
jammerrs
pmsl at the 'n95 8 injector conversion'
something that turns rust to solid metal instantly would be sure to be a huge hit
id like to see one make 1000bhp on english rollers (unless this has been done!?)
i dont think theres many mechanical things for the engines left, its all modern electronics now a days unless like Paul S says and they can make some lighter parts
Old Mar 23, 2010 | 05:42 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I'd be quite surprised but pleased if someone bolts on a bigger turbo than mine on a standard ported head and didnt encounter surge and have to cap the boost.
Wouldnt call magnetic drain plugs a big thing either.
Agree with Rod - a cheaper Accuvolt system. I look at my volt gauge more than any other if im honest just because i have seen the results of an alternator failing when on the loud pedal
Old Mar 23, 2010 | 06:04 PM
Chip's Avatar
Chip
Congratulations mate, you must be getting smarter if you are now getting the correct answer more often
Old Mar 23, 2010 | 06:05 PM
Ryan's Avatar
Ryan
can the ecu not control the flow rate of the pump on the autronic and vipec?
i.e on several motec systems i have worked on they run several failsafe strategies, one being if the ecu power drops below a certain power the ecu triggers a failsafe strategy which puts the map in limp mode and slow the rate of the fuel pump also to save failure.
Old Mar 23, 2010 | 06:06 PM
Chip's Avatar
Chip
Assuming mark has set the voltage compensation table correctly (which im sure he has) it shouldnt actaully harm the engine if it runs low on voltage, although im not saying its a good idea to do so reguarly of course.
Old Mar 23, 2010 | 06:08 PM
m4tt274's Avatar
m4tt274
almost exactly what i was going to type.
Old Mar 23, 2010 | 06:09 PM
Chip's Avatar
Chip
How I have mapped my nova, it will lengthen the injector duration to allow for a drop in voltage at the ecu.
I cant imagine why you would want to slow the pump though, then you would get a drop if pressure too, and surely that is the last thing you want?
Unless you are monitoring the fuel pressure you are pretty much fucked once the pump stops working well enough to maintain pressure though, you would never be able to guess at it well enough, so the trick is just to get the ecu to stop allowing boost once the voltage drops enough that you believe fuel pressure has become a problem.
CossieRich's Avatar
CossieRich
It does run on low voltage indeed. Just ask Rod how low a voltage i can run
But i really dont like it if im not seeing 14 at the battery mate
Old Mar 23, 2010 | 06:14 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Didnt mention harming the engine Chipus just keeping 15v to the pump even when alternator fails & battery starts to drop.
Old Mar 23, 2010 | 06:19 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah yeah,cunt.
Old Mar 23, 2010 | 06:34 PM
Sonic Boom's Avatar
Sonic Boom
My T66 is on a standard ported head peaks at 2.2 bar (on the road) 1.9 bar (on the dyno) and doesn't have any surge, but yours does make about 70 BHP more
Rich
Old Mar 23, 2010 | 06:42 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I want to do a twin charge conversion, and would be nice to see VNT technology filter down onto aftermarket turbos, be nice in either instance to fill that area under the graph in big 450+ cossies.
Old Mar 23, 2010 | 07:10 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
coil on plug conversion ----- talk to me ?
very intrested in this as i plan to run it on this bad boy
was tempted to go for autronic or vipec but if its possible to run it via l8 ?
anymore info simon ,
beef
Old Mar 23, 2010 | 07:20 PM
CossieRich's Avatar
CossieRich
Rich
Rich,
If you have no surge, and i assume there is no capping of the boost in the midrange and it makes as much boost as it can, as early as it can, then i would have thought with a mildly mental inlet cam you would wipe the floor with my car especially if you run 2.5 bar the T66 is massive isnt it?
Old Mar 23, 2010 | 07:57 PM
Sonic Boom's Avatar
Sonic Boom
I'd love to try a bigger inlet cam but i'm pretty sure the pistons aren't pocketed althought they are low compression. Ye it just makes as much boost as it likes Martoon set it up and it is lazy as you can see from the graph but doesn't drive a bad as the graph looks. Martin reckons it just so big that there is just not enough air low down in the range to spin it up so it doesn't surge at all. (Big ports and massive cams would help) It made that power at 1.9 Bar on the dyno but makes 2.2 Bar when driving on the road!?!? So it might be more not sure if you get more load on the road?
Rich
Old Mar 23, 2010 | 09:45 PM
stu21t's Avatar
stu21t
renault 5s have been running vnts for years with good results.
will be nice to see it hit the cossies
Old Mar 23, 2010 | 10:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Replaced with JAP engine of sort's.......
Old Mar 23, 2010 | 10:33 PM
fiend's Avatar
fiend
Weird, was going to post the exact same thing.
Old Mar 23, 2010 | 11:39 PM
puddy's Avatar
puddy
EGR , Constant boost systems ?
Puddy
Old Mar 24, 2010 | 12:05 AM
Originally Posted by R4N S S
an S8 ECU
Coont
The ecu was good, it was me who failed
A small bit of extra development and backing could have made it very good .. IMO of course
Its only expensive due to the way its marketed , the technology isnt expensive or complicated
Yes I have developed a coil on plug adaptor for my personal car.
I will be doing a resto thread detailing my car soon
The old secs monitor rights and design are being transfered to a PF official trader including updated software that sorts that out.
I am sure that trader will make an announcment very soon
I like this !!!!!!
I have often thought about adapting an existing BMW system onto the YB but it isnt very good on the BMW so will be shit on a YB... lol
Knock link
Only in so much that on some cars, the heat of the engine can destroy the coils over time but those cars that have that problem are using shit coils in the first place
In fact this is the ideal ignition system if implemented properly.
I like this too !!
I think I will have a go at making one of these myself too !
very intrested in this ........ was tempted to go for autronic or vipec but if its possible to run it via l8 ?
beef
The existing MSD coilpack driver board will run coil on plugs no problem.
Except, the coils are wired in pairs so effectively its a wasted spark system.
The one I have made for my own car is truly sequential
Old Mar 24, 2010 | 12:09 AM
I love the way people make comments like "who fucking cares" in the tags... well you do, as you read the thread you stupid cunt(s)
Old Mar 24, 2010 | 12:24 AM
.Ross.'s Avatar
.Ross.
Dont know if there would be room or need but ... High n Low Turbos .. (sequential)
Old Mar 24, 2010 | 12:39 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
So by that reasoning on P8 with wasted spark activated via pin 26 you could run coil on plug in a wasted spark way too???
Old Mar 24, 2010 | 07:58 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
already been done controlled by a pectel ecu
cossie owners weren't prepared to pay all those years ago
Old Mar 24, 2010 | 08:18 AM
p17fld's Avatar
p17fld
welding two together to make a v8
Old Mar 24, 2010 | 08:33 AM
charlie luciano's Avatar
charlie luciano
I'm glad you took notice of that cos it was mine, unlike a lot of people who add tags and stay hidden I'll always put my hands up to it and the only cunt is you, you scammer fucking thief, fuck you
Luciano
Old Mar 24, 2010 | 09:21 AM
Chip's Avatar
Chip
The trouble with running COP wasted spark is you are of course doubling the amount of work done by each COP, and with them already prone to failure in lots of instalations when running big rpm, thats obviously the last thing you want to do.
Given that the L8 is already sequential for fuelling and has the phase and crank sensor required accordingly I am sure it was pretty minimal extra effort to run it sequential, just a case of physically needing a couple more wires that makes it more difficult from a plug and play point of view as you must be running out now on the standard loom plug!
Old Mar 24, 2010 | 09:34 AM
R4N SS's Avatar
R4N SS
best of luck in what you do Simon - you are very good at engineering but utter crap at business so hope you can overcome your shortfalls from the previous attempt
