what is the difference here?
Old Mar 21, 2010 | 10:33 PM
Imperialrs's Avatar
Imperialrs
Default what is the difference here?
what is the difference Between a sapph xr4i and a sapph cossie in terms of the running gear
obv the engine and loom and fuelling system are different
but is the suspension, hubs, diffs,prop shaft, brakes etc more or less the same?
mates got a nearly new sapph cossie bare shell and is going to make it a cossie, and have the opportunity to get hold of a 4i sapp to transgfer majority of teh runnign gear over?and then get hold of the cossie engine last and the bits that cant be taken from the 4i?
thanks in advance guys
thanks in advance
Old Mar 21, 2010 | 10:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No such thing as a 4i saph
On a 4i all the hubs brakes etc are different
Steve
Old Mar 22, 2010 | 09:51 AM
Cossie hubs are different to std 2wd hubs, which is what xr4i uses, suspension rates all different, cossie prop different, and importantly has CJ13 flange at diff, styd one would break with cossie power, xr4i uses 260mm discs single piston sliding caliper 2wd cossie uses 283mm 4 pot calipers with rear discs(273 solid).
All the 4i stuff could be used as upgrades went along though allowing you time to find the needed bits.
Cossie has lsd, 4i doesn't, defo needed as well, as is rear discs.
Old Mar 22, 2010 | 09:58 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Do you mean a 2.0 4wd saph?
If so as far as im aware there isnt any difference in the running gear (other than maybe the rear diff not being an LSD) from that to a cossie, but its not something I know a lot about so im sure someone can give a more definitive answer.
Old Mar 22, 2010 | 02:03 PM
martysmartie's Avatar
martysmartie
No such thing as Saph 4I, 2.0 4X4 does has rear LSD as is the same running gear as used in 4x4 Cosworth!
Rest has been answered above.
Martin
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
