Sapphire Cossie 4x4 Front Wheel Bearing Grease Seals?
Old Mar 20, 2010 | 10:42 PM
redzuki1's Avatar
redzuki1
Default Sapphire Cossie 4x4 Front Wheel Bearing Grease Seals?
One question chaps...
Front wheel bearing dust caps/grease seals on a sapphire cossie 4x4 - does the metal circular retention spring face out of or into the hub itself? I'm guessing you push the seal's first lip over the outer edge of the bearing and then butt the second seal lip against the outer face of the bearing itself? Sound's like a good story to me?
Thanks in advance guys.
Alex
Old Mar 22, 2010 | 10:39 PM
forevaford's Avatar
forevaford
rubber part of the sealls facing outwards
Old Mar 24, 2010 | 10:50 PM
redzuki1's Avatar
redzuki1
I know this to be true, only after installing the other way around, inserting the hub and pushing the seal into the wheel bearing race iteslf. Sad times. Junior error. Fixed now. Won't do that again. Doh.
Thanks.
jason_nike
Aug 18, 2019 10:53 AM
malkiemac3579
Jul 14, 2017 12:10 PM
pegaz
Aug 12, 2015 07:30 AM
muz
Aug 1, 2015 06:48 AM
Old ford
Jul 31, 2015 06:50 AM
