Diagnostic Plug Pin Assignments
Old Feb 13, 2009 | 02:06 PM
bunjeeman's Avatar
bunjeeman
Default Diagnostic Plug Pin Assignments
Does anyone know the pin assignments for the diagnostic plug for the Escos under the passenger side tower brace?
Cheers!
Old Feb 14, 2009 | 08:24 AM
bunjeeman's Avatar
bunjeeman
Thoughts anyone?
Thanks!
Old Mar 24, 2010 | 10:57 PM
cesco.manto's Avatar
cesco.manto
Default Ecu specs ans 4.000 rpm problem
hi, if you want i have a technic specification for marelli iaw p8 escort cosworth ecu. You can test your ecu plug by a normal tester and see wath's wrong with wich one sensor. I have problem with my escort cosworth because i don't go over 4.000 rpm like a limitator, as recovery by ecu for some sensor wrong. I think that my 3 bar map sensor doesn't work correctly ... I change it with original eeprim and original 2bar map sensor but is the same problem. I read some worng valuse on pin 4, crank pulley sensor...
Brickhouse
14
Oct 3, 2015 07:28 PM
muz
Sep 30, 2015 08:29 AM
deathrider666
Sep 28, 2015 06:12 PM
