My 1991 Ford Sierra 2.0i DOHC 8v Turbo
Old Mar 17, 2010 | 04:39 PM
mhs's Avatar
mhs
Smile My 1991 Ford Sierra 2.0i DOHC 8v Turbo
Hi All
Turbo SİERRA 2.0i DOHC
•Stage-3 T3/T4 Turbo (Cut back blades, 360° bearing & .63 exh housing)
• Intercooler 27x6.5x3 (Direct Bolt-on)
• 2.25 Aluminized Mandrel Bent Piping (Total of 4)
• High Pressure Silicon Hose (Total of 6)
• Tial Blow Off Valve
• Tial External Waste gate 38mm
• Stainless Steel sus 304 Custom Turbo Manifold
• 2.5 Stainless Steel Down pipe
•NNOVATE LC1 Wideband
•AutoMeter Oil Press,Oil Temp,Boost Guage
Turbo spec
T3/T4 turbo
Intake: 3 inch
Inlet: 2 inch
Compressor trim: .50
Compressor Wheel diameter: 50.16 / 76.84
Turbine Wheel diameter: 54.06 / 65.20
Exhaust Trim: .57
Turbine flange type : T3 flange
Down pipe flange type: 5 bolt standard
Cooling type: oil cool only
Horsepower rating: 350+
Engine Spec
Wössner Custom Forged Piston 86.50
Fomoco Ford Main And Rods Bearing STD
Fomoco Ford Oil pomp
Fomoco Ford Orjinal Metal Head Gasket
Custom Sinter Bronz Clutch
Old Mar 17, 2010 | 05:05 PM
m4tt274's Avatar
m4tt274
looks like it should be pretty good.
would it not have been cheaper to have just bought a cosworth?
Old Mar 17, 2010 | 05:08 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Thats what i was thinking, But hey it's different and i like it. should be a cool car
Old Mar 17, 2010 | 05:20 PM
mhs's Avatar
mhs
thanks
What can we do with Turbo DOHC 8v to see him
Old Mar 17, 2010 | 05:28 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Love cars like this, get some vids up when done
Old Mar 17, 2010 | 05:32 PM
mhs's Avatar
mhs
Thanks
roads soon target, 20 PSI of boost HP ?
Old Mar 17, 2010 | 08:12 PM
OrionRST200bhp
got to be well over 250bhp if set up right
Old Mar 17, 2010 | 08:14 PM
m4tt274's Avatar
m4tt274
what compression are the pistons?
its hard to say what power ul have but it could be anywhere between 250bhp-400bhp
Old Mar 18, 2010 | 05:34 PM
mhs's Avatar
mhs
I guess ,22 PSI Boost with 300,350HP
Old Mar 18, 2010 | 05:37 PM
mhs's Avatar
mhs
Piston CR 7.1 ,Metal Gasket 1.5mm
Old Mar 18, 2010 | 05:48 PM
jonny s2's Avatar
jonny s2
awesome project pal keep it up
Old Mar 18, 2010 | 05:52 PM
mhs's Avatar
mhs
Thanks
Old Mar 18, 2010 | 06:05 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
well done this is wicked mate
Old Mar 18, 2010 | 06:23 PM
mhs's Avatar
mhs
Thanks mate
Old Mar 28, 2010 | 12:25 PM
mhs's Avatar
mhs
Refreshing Turbo DOHC Sierra
Old Mar 28, 2010 | 12:47 PM
boothy's Avatar
boothy
Lookin goode mate
Old Mar 28, 2010 | 12:56 PM
mhs's Avatar
mhs
Originally Posted by boothy
Lookin goode mate
thanks mate
Old Mar 28, 2010 | 01:01 PM
Csm's Avatar
Csm
Likin this fella
Old Mar 29, 2010 | 07:19 PM
Mark_'s Avatar
Mark_
fantastic to see a project like this,
not everyone wants a cosworth so it is refreshing to see something different
Old Mar 30, 2010 | 04:57 PM
mhs's Avatar
mhs
thanks
Old Aug 8, 2010 | 08:29 PM
mhs's Avatar
mhs
Welcome Megasquirt ,bye bye EEC-IV and engine loom
Old Aug 9, 2010 | 10:27 AM
wess-rs's Avatar
wess-rs
Nice sleeper!!
Old Aug 9, 2010 | 02:53 PM
Zetecfiesta's Avatar
Zetecfiesta
cool car!
Old Aug 9, 2010 | 07:44 PM
mhs's Avatar
mhs
thanx all
Old Aug 9, 2010 | 10:45 PM
turbo m's Avatar
turbo m
Should go like stink .andy rouse turbo"d some of them in the early 90"s too keep the pics comming..
Old Aug 10, 2010 | 01:03 AM
ÖmerRS's Avatar
ÖmerRS
Looks good with Cosworth bumper.
Güle güle kullan.
Old Aug 13, 2010 | 06:19 PM
mhs's Avatar
mhs
thanks friend
I add new pictures update ,new exhaust system, etc.
Old Aug 13, 2010 | 06:20 PM
mhs's Avatar
mhs
Güle güle kullan.
Teşekkür ediyorum Dostum bu araba için biçilmiş kaftan başka bir tampon düşünemiyorum
Old Aug 13, 2010 | 06:32 PM
mr noisy's Avatar
mr noisy
I have same engine and wanting to make it turbo power not for big BHP just the puzzled look when bonnet is open
What PSI do you think i can run on std engine ??
Old Aug 13, 2010 | 06:48 PM
mhs's Avatar
mhs
thanks mr noisy
Max 10 PSI with 10.3 cr
I've used low-cr forged pistons
now I'm running with 21 PSI boost
Old Aug 13, 2010 | 07:34 PM
mr noisy's Avatar
mr noisy
cool cool gonna sound very dumb now but what do you mean by 10.3 cr ??
Old Aug 13, 2010 | 07:51 PM
mhs's Avatar
mhs
compression ratio 10.3
Old Aug 18, 2010 | 01:43 PM
DOHCUGUR's Avatar
DOHCUGUR
Thumbs up Hayırlı olsun Usta Mükemel
Selam USTA,
Ben bu Motoru tam 10 yıldır Scorpiomda kullaniorum.
Gercekden mükemell bir sonuc hayran kaldım,Almanlar sizin yapdınız işden bile korkiordu.Ben Almanyadan Türkiyeye temerli dönüş yapdım,ve benim DOHC icin cok zor parca bulabiliorum,usta siz nerden buldunuz bunları?????? hele Türkiyede zanetdim kadar cok zor.Gercekden temiz ve süper iş yapdınız,DOHC ye Turbo takmak pek bassit bir iş olmadını biliorum tebrikler.http://
Aslında Cosworth 24V motorunu takmak istiorum Vitezli,ama bunu gördükden sonra düşünmeye başladım
Benim Arac budur Scorpio MK1 Facelift RS: http://www.google.com/url?sa=t&sourc...GIWGJLlY-uv8bg
Old Aug 19, 2010 | 10:23 AM
DOHCUGUR's Avatar
DOHCUGUR
DOHCUGUR's Avatar
DOHCUGUR
Old Aug 19, 2010 | 08:21 PM
mhs's Avatar
mhs
Teşekkürler aracınız çok diri ve güzel görünüyor.DOHC motor beklentilerimizi çok çok fazlası ile karşıladı. TR şarlarında gerçekten zor bir iş modifiye parçası bu motor için yok hiç bir firma üretmemiş zaten, debriyaj balatası piston bunlar özel yapım
diğer parçalar orjinal fabrikasyon parçalardır turbo uygulamasında orjinal parçalar çok başarılı oldukça kaliteli hiç bir problem ve aksaklık yaşamadık şu ana kadar 1 bar boos ile 350hp lerde çok sağlıklı problemsiz yürüyor
Old Aug 20, 2010 | 09:24 AM
DOHCUGUR's Avatar
DOHCUGUR
Selam,
Tek tanıdım Şirket DOHC Motoru icin parca üreten SUHE Motorsport,Motor icin bir kac Modifiye Parcaları var:
http://www.suhe-motorsport.de/
Bu sayfada 1 kac ürün var N9 DOHC Motoru icin
https://passionford.com/forum/pictur...ictureid=15687
Peki Usta Şansuman Originalmı kaldı? nasıl dayanior bu kadar Newtonmetre Güce?
Old Aug 20, 2010 | 01:01 PM
zippyobrien's Avatar
zippyobrien
i take it its got a rs2000 16v head as your pistons have 4 valve cut outs?
Old Aug 20, 2010 | 04:17 PM
mhs's Avatar
mhs
Originally Posted by DOHCUGUR
Selam,
Antalya taraflarına yolun düşerse beklerim şanzuman orjinal ancak dediğim gibi orjinal debriyaj balatası çok zayıf ,el yapımı yukarıda resimide olan sinter bronz debriyaj balatası yaptırıp balata kaçırma problemini çözdük.
bunun dışında şanzıman ile alakalı bir problem hiç yaşamadık MT75 çok sağlam. dediğim gibi şu anda 1 bar boost ile 350 hp lerde turbo basıncını 1.8 lere çıkarıp tekrar bir beyin ayarı ile daha fazla güçlere ulaşmak mümkün enjektörlerimiz şimdilik bu kadarına izin veriyor 1000cc enjektörler ile bunu mutlaka deniycez ve en son aşamada 2.3 scorpio 16v kapak silindir kapağını değiştirip emme ve egzos manifoldları el yapımı olacak projeyi tamamlıycaz
Old Aug 20, 2010 | 04:19 PM
mhs's Avatar
mhs
thanks
I think the next stage, scorpio 2.3 16v head
