Cement
Old Mar 16, 2010 | 05:20 PM
T28 RST's Avatar
T28 RST
Ok then
Default Cement
Im going to be building a 6ft fence soon and was wondering what was the best cement to use for the posts
Old Mar 16, 2010 | 05:24 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Cement is cement really?
Use more in your mix if you think it needs it?
Old Mar 16, 2010 | 05:25 PM
5t1g's Avatar
5t1g
Shotgun Bunter
Get the stuff that comes in a bag. One bag per fence post. Job Jobbed
Old Mar 16, 2010 | 05:31 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Absolutely right - Postcrete is what you want. Goes off real quick so it doesn't take hours to go each post. Mix with ballast dry in the hole after putting the post in, water in, leave 10 minutes and onto the next one.
Old Mar 16, 2010 | 05:41 PM
T28 RST's Avatar
T28 RST
Ok then
What size of bag am i after
Old Mar 16, 2010 | 05:46 PM
stevenebm's Avatar
stevenebm
post whore
im just building a 6ft fence right round my garden just now.its hard work.need 8 ft posts and dig down 2ft which is a task.get postcrete from bq Ł3.70 per bag when you buy ten or morethey only come in like 25k bags..you will need 2 bags per post.fill the hole between 1/3 and half with water and pour in the postcrete.simple as that.good luck with it as it aint easy and dont envy people who do this for a living.
Old Mar 16, 2010 | 05:50 PM
stucos71's Avatar
stucos71
As said above, Postcrete is the stuff to use.
1 bag per post. Its about Ł3.60 a bag, but usually get a deal in B&Q if you buy more than 4.
Steven- never used 2 per post before? Usually once its set, should be able to hard pack the post with muck etc from the hole.
Old Mar 16, 2010 | 06:17 PM
Spax's Avatar
Spax
I'd mix in sum gravel to make it stronger
Old Mar 16, 2010 | 06:33 PM
stevenebm's Avatar
stevenebm
post whore
anyone ive spoke to says use two bags.even the back of the pack says it for 8ft posts.everyones different i suppose.your happy with one and im happy with two,tho the wallet isnt i suppose
Old Mar 16, 2010 | 06:36 PM
Graham S1's Avatar
Graham S1
Postcrete. Most builders merchants will sell it or similar. Goes off much quicker than regular cement.
Old Mar 16, 2010 | 06:38 PM
stevenebm's Avatar
stevenebm
post whore
im using 4" posts aswell this only shows up to 3 3/4" posts
12" diamater by 24" deep says 2 and 3/4 bags.if you have a proper tool to get a decent sized hole id use less bags but diggin down with a thin spade isnt easy for that.
http://shop.parkerbs.com/pub/files/L...246_H02593.pdf
Old Mar 16, 2010 | 06:39 PM
stucos71's Avatar
stucos71
Too true mate, does cost a few bob when you add it all up. I just used one iirc, last one i done. Was a while ago tho.
Using 2 reassures it wont fall down lol. Cant have the fence falling on that minty Focus Steven.
Old Mar 16, 2010 | 06:43 PM
capri280's Avatar
capri280
better putting posts in with concrete
mix your own or get it delivered
tony=m=
Concours d'élégance.
Jul 27, 2014 12:35 PM
lardypants
24
May 16, 2008 06:35 PM
Trist
Feb 19, 2008 06:09 AM
